Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
ADMIRAL SIDE BY SIDE COILS FREEZING UP
I have an ADMIRAL side by side fridge. The coils keep freezing up and I have to blow dry them every month... HELP!
Sounds like a defrost problem. most of the time it's the heaters behind the coils.
Posted on Aug 13, 2008
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Coils in freezer freezing up
You have a defrost problem.
Apr 26, 2009 | Refrigerators
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge and freezer not cold and frozen up
Can you remove the back panel inside the freezer and defrost the coils. Use a shop vac with the hose in the blow position instead of the vacuum position. And blow on the coils to defrost quickly. Hair dryers work also but prolonged use will burn up hair dryers. Now turn back on and see if the inside the freezer fan works. It should be running to keep the coils from freezing up. Also could be defrost timer. But this will be enough to get you going. Let me know how it goes. ken
Jan 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Coils In Freezer Keep Freezing
check continuity thro defrost heater and check thermal cutout in series with the defrost heater
Aug 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
244 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
