Question about Whirlpool Freezers
Adding R134a What line do you use to add coolant to a freezer that has never been recharged?
    Problem Solver:
  • 13 Answers
You have to go on the high pressure side. It means that it would be better to put a acces valve on before the dryer. The 134A needs to be charge liquid to make sure that the bottle is upside down. Hope it was helpful. :)
Francois
Posted on Jan 21, 2009
I had it recharged to 4.8 oz
OK, so you had it recharged to 4.8 oz.
Now, what happened next?
Jun 29, 2015 | Whirlpool EV250NXT Upright Freezer
Www managemyhome com
I would suggest you have it serviced, sounds like the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
Jan 04, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Samsung RSG257AARS, freezer is not cooling things. What can the problem be?
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
It might be that the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
Jan 03, 2014 | Samsung RSG257AARS - 24 cu. ft. Side by...
Freezer will not shut off some things frozen, bread and ice cream soft
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Where and how to add freon to upright freezer
I did one earlier this summer. Took some pix. Check this out: Freezer recharge
Oct 23, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Need to recharge a unit. What type of oil is used?
Good day,
If it's an R12 system it uses mineral oil. If R134A it would be esther oil which is alcohol based.
You would need to go to a commercial refrigeration store to buy it. They will know what you need, however, if no oil has been lost there is no need to add additional oil. That is a car thing, and does not apply generally to appliances.
Nov 05, 2010 | Kenmore Freezers
How do i add freon to system
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
Sep 30, 2010 | Magic Chef Chest Freezer MCCF5WBX
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Mar 29, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Condensation on base of Hotpoint R134a upright freezer
sounds as tho you have an insulation breakdown. no repair except to refoam - and that is difficult to do
Aug 09, 2008 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezers Logo
212 people viewed this question
Top Whirlpool Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
David Jewell
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
