Question about Sharp R-1405 / R-140 Microwave Oven
Sharp Microwave Oven R-530BK
The microwave was working fine and I unplugged it to move it to a new apartment and the display now only shows a portion of the numbers. The microwave still works, but the numbers are only half displayed. Please advise as to what to do to fix this problem.
Thank you!
  • ampex1951 Oct 27, 2008
    Jim
  • Sharp Master
  • 9,086 Answers
We repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
http://nzlamb.wordpress.com/2010/04/10/sharp-carousel-microwave-lcd-repair/
Aug 12, 2011 | Sharp R-1750 Microwave Oven
Sharp R-630D Display Problem
Usually switching off and removing plug for couple of minutes solves this problem if not then its going to need replacing as a resistor has probably gone on the display board unplug it then let me know what happens ok
Apr 21, 2008 | Sharp R-630D Microwave Oven
Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Oct 24, 2009 | Sharp R-510HW Microwave Oven
The numbers don't show on the microwave.
the board has come unplug or the transformer is bad.the voltage is lost on the board
Mar 12, 2009 | Sharp R-1500 Microwave Oven
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
William E. Miller
prototech@usa.net
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Sharp R-230 Microwave Oven
Microwave Display
Have you tried unplugging the unit for several minutes and then plugging it back in?
The oven's microprocessor receives the input commands from the front panel switches and it also drives the digital display.
Since the switches work and the oven works, the microprocessor appears to be functioning fine. I would say you have a defective display or a power supply issue that powers the display.
Unfortunately, you'll need to take it to be serviced.
Please let me know if I can be of further service to you.
- Jim
Feb 17, 2008 | Sharp R-1405 / R-140 Microwave Oven
Sharp R-402JKF microwave
It sounds like your electronic board has malfunctioned. It may have to be replaced, sometime it is cheaper to buy a new oven. Technician's fees and parts may be more than it it worth.
Dec 25, 2007 | Sharp R-402J Microwave Oven
Sparking/growling NEW microwave
Don't use it! Unplug it and take it back to the dealer-sounds like a loose wire or short.
Jun 24, 2007 | Westpoint TV-201 Microwave Oven
Sharp R-1405 / R-140 Microwave Oven Logo
151 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
