Question about Apple InFocus X1 Multimedia Projector
The bulb works but I can't get an image
My Infocus X1 projector has worked OK until recently, but now when I switch it on, the bulb comes on, but I cannot get an image appearing. Any clues?
    Guru:
  • 1,894 Answers
Is the projecting image black or what??
what is being projected actually??
have you checked the lens section?
Posted on Aug 11, 2008
Black and white specks from InFocus X1 projector
if you can get a menu when you press the menu button, reset the settings to factory default. if you don't get a menu, the color wheel or the dmd chip is bad. either way, you'll have to replace the entire optical engine. and unfortunately, infocus no longer has any more in stock.
Sep 06, 2009 | InFocus X1 Multimedia Projector
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
INfocus X1 does nothing after bulb replacement
first off, make sur you have the right lamp (sp-lamp-009, 2 white wires. not the sp-lamp-018, one white, one red. the wires are in different locations in the plug). if you don't hear the colorwheel whirring, that'd be the next step. however, you cannot buy just the colorwheel. infocus does not sell individual parts of the optical engine. but that wouldn't matter, seeing as how they don't sell the engine anymore. also make sure the lamp door is completely closed. there is a peg on it that activates a switch to let the projector know it's closed. if you remove the lamp and use a flat-head screwdriver to activate that switch, turn on the projector. look inside the lamp housing and see if the colorwheel spins. if not, i think you need a new projector. if it does, check the fans. they can be replaced.
Dec 19, 2008 | Apple InFocus X1 Multimedia Projector
Infocus X1 lighting problem
Well there are only a couple of things that could cause this problem. However considering this all started when it was mounted consider the possibility you may have used screws that are too long and are is/are subsequently shorting something out.
Cheers
Oct 14, 2008 | Apple InFocus X1 Multimedia Projector
Proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Sep 05, 2008 | InFocus X1 Multimedia Projector
Your comments
you need to replace the controller eca (main board)
Aug 13, 2008 | Apple InFocus X1 Multimedia Projector
Image Problems - Grainy Black and White Image
Hello Carmen,
Well this can usually be caused by one of two things.
#1 the main board has failed and needs to be replaced.
#2 The firmware's flash data has been corrupted and need to be re-flashed. Both of these solutions will need to be performed by an authorized technician.
I have parts for these projectors if you want to learn more regarding this you can contact me at,
dennis@sagertronics.com
Take Care!
Aug 09, 2008 | InFocus X1 Multimedia Projector
Apple InFocus X1
It seems like your main card is not functioning.
pls check :
1. Color wheel is rotating or not.
2. Recheck Main card connectors.
mail me for any changes
Viren
Jul 16, 2008 | Apple InFocus X1 Multimedia Projector
Infocus x1 keypad.. need help
the same functions should be able to be accessed via the remote as well as the keypad on the projector. press "menu", settings, system and de-select "rear" or "ceiling" whichever is causing the "inverted" image
Feb 05, 2008 | InFocus X1 Multimedia Projector
Apple InFocus X1 Multimedia Projector Logo
167 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
