Question about JVC Cybercam GR-D72 Mini DV Digital Camcorder
Lens cap? Hi, when I turn on the camera using either the viewfinder or LCD screen, lens cap appears on screen (actual lens cap is off) and the screen remains blank!? what do you guys think-
I just had this problem and was going to replace the camcorder. My husband took the lens cap off, placed the camera in the sun for about an hour then flicked (not banged or beat - just a light tapping) and now its working. He said condensation, dust, lack of use, etc may have made the lense stick. Good luck!
Posted on Aug 17, 2008
  • 2,794 Answers
Try removing the battery, wait 30 seconds, and plug it back in. That may reset the lens cap sensor.
Posted on Aug 11, 2008
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Black screen on my s6500 fd
I assume you removed the lens cap...;-)
If both the viewfinder and the screen is black, it is most likely an error on the CCD. If the viewfinder is OK, but the screen is dead, the problem is probably the LCD.
Hopefully you still have warranty on the camera?
Oct 02, 2009 | Fujitsu Cameras
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
My Canon 300D SLR will turn on, and led display comes up saying battery is full and yet when you go to take a photo you cant see anything but black through the lens.
Obvious Questions, but you didn't supply the information.....:
1. Is the lens cap off?
2. Are you looking through the viewfinder? You will *NOT* be able to use the LCD screen as a viewfinder.
Otherwise, there is always a light path through the lens to the viewfinder, so....
1. Have you tried a different lens?
2. Have you checked the mirror is down?
May 26, 2008 | Canon Cameras
Viewfinder/lens problems
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance. Really, you'll slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
And yes, your camera's optical viewfinder is off by a couple inches from what's show in the LCD. Take a look at the front of your camera. This offest is equal to the distance between the other end of the optical viewfinder, and your camera's lens. This should only be a problem for close up pictures. Recommend leaving your LCD on and using that to center your pictures. If using rechargeables, it shouldn't be a problem.
Jan 30, 2008 | Canon PowerShot A430 Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
JVC Cybercam GR-D72 Mini DV Digital Camcorder Logo
357 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
