I have a Sharp Aquos 37 inch tv and have an issue. When you press the channel "up or down" button you receive an error message and cannot advance the channels. I requested a new remote and received the same message. Any ideas?
  • vz1kts Aug 11, 2008
    I am at work now..I will have to check when I get home and get back to you..
  • vz1kts Aug 13, 2008
    Worked just fine..thanks!
    Master:
  • 521 Answers
Rescan n restore the channels will remove any channel lock error n u will be able to enjoy the normal use.
Posted on Aug 11, 2008
  • 2,322 Answers
You will need to do a scan to store all the channels in the LCD memory.
What is your LCD model number?
  • Jaime Hernandez Aug 12, 2008
    Click here to download the user's guide and go to page # 16 step 2 to select "cable" or "air", on step 3 go down to do a channel search.
    Let the LCD finish the channel search, it should take up to 10 minutes to complete.
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Is there a reset button on the 27 inch sharp aqua tv?
  • Press "Menu" on the TV's remote control and use the arrow keys to scroll to "Setup."
  • Scroll down to "Reset" and press "Enter" on the remote.
  • Select "Yes" using the arrow and "Enter" buttons at the "Return To The Factory Preset Values" message.
  • Select "Yes" using the arrow and "Enter" buttons at the "Now, TV Will Restart Automatically. OK?" message.
  • Wait while "Now Initializing..." appears on the screen. The TV will power down and turn back on when the reset is complete.
  • Read more: How to Reset a Sharp Aquos ' eHow.com http://www.ehow.com/how_7225301_reset-sharp-aquos.html#ixzz12i633RwM
    Oct 18, 2010 | Sharp Televison & Video
    "Failed to receive broadcast"
    On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
    Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
    Speaker distortion on SHARP 37" Aquos Hi Def
    When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
    Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    Sharp Aquos HDTV Failed to receive broadcast
    I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
    Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
    Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
    First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
    Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
    Sharp AQUOS LC-60C52U
    hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
    Sep 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
    This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
    Aug 13, 2008 | Sharp Aqous LC-26D5U Television
    Lcd sharp tv flashing green light
    Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
    Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    RCA tv
    Check the signal type. It may be set incorrectly. Change the channel. You may be on a blank channel. Check to see if the TV is tuned to channel 3 or 4 if you are watching a videotape. Check the TV/VCR button on the VCR is in the correct mode by pressing the TV/VCR button on your VCR.
    Aug 11, 2007 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
    Televison & Video Logo
    49 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
