Question about Dell Dimension 3000 PC Desktop
Dell Dimension 3000 yellow light blinks, PC will not start
When I power up, the green light goes on, but the yellow light blinks and the CPU will not boot up.
  • 3 more comments
  • zemay2k10 Nov 13, 2008
    hi, When i turn it on, it does not beeps but the yellow light blinks, cpu fan shuts off. does anybody know what could it be?
  • cyberlaw22 Dec 03, 2008
    pc boots up fan turns on everything turns on but no boot
  • pdsreid Apr 11, 2009
    when I start i get a yellow light in the push button PC wiull not boot up i have switch off ant mains switch on and start again
  • Laurentiu TUDOR
    Laurentiu TUDOR May 11, 2010
    What color code of back panel lights do you have? It's 4 led's each of them may have 4 state. off, blink, solid yellow or solid green.
  • confusedbrit
    confusedbrit May 11, 2010
    Is there any beeping noises?
I get beeps, but no screen display.
Posted on Oct 06, 2008
  • 600 Answers
Could be a bad driver..try booting into safe mode F8
Posted on Apr 12, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
When trying to turn on CPU the power button only blinks yellow but cpu dont come on
The power supply is likely bad. Check the back and see if it has an LED lamp - I think it's a green color near where the power plugs into. If it's not lit or is flashing, then the power supply IS bad.
Feb 10, 2011 | Dell Dimension 8300 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 3000 just stopped working, no sound, no picture. Power supply comes on, hard drive light blinks as if it is trying to load, but, nothing.
just reinsert your RAM.
its not a graeat problem. so just open your cpu and eject ram and insert it again properly. okay
Apr 26, 2010 | Dell Dimension 3000 PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 3000 flashing yellow light
Replace the power supply with a known working one. If it goes away then you know that the original power supply is bad.
If it doesn't go away with the new power supply then you know the motherboard is bad and would need to be replaced.
Jun 26, 2009 | Dell Dimension 3000 PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 3000 PC Desktop Logo
1,087 people viewed this question
Alun Cox
