Question about Toshiba Satellite M35X-S111 Notebook
Wont bootup have a toshiba laptop. message on bootup PXE-E61- media test failure PXE-MOF exiting PXE ROM it stays stuck in this loop. i tried to run the recovery CD and i grt to press "C" to continue it goes to a blinking prompt and that is as far as it goes
  • 1 more comment
  • coffeety Sep 12, 2008
    I have the same M35X-S111 laptop and my HD crashed. Try using Repair CD, but it won't bootup. Got the same "Media Test Failure" PXE message. Is this a HW problem?
  • sloneranger May 02, 2009
    how do I get to cmos
    regards
    Roger
    regards
    Roger
  • 61 Answers
Try to run cmos and set it to factroy default.
Posted on Feb 16, 2009
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
Toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Jun 16, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
PXE MOF problem
First, try and access your cmos setup. Look to see if your harddrive shows up.
Apr 06, 2008 | Toshiba TE2100 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
