Question about Whirlpool Calypso GVW9959K Top Load Washer
I forgot to empty pocket. a ball point pen exploded and i have ink all over the inside of my dryer. I have not found anything to remove it. Any suggestions?
    Novelist:
  • 158 Answers
Try aerosol hair spray. It removes dried ink from clothes, may also work for your dryer. If not, try paint thinner or mineral spirits, available at any hardware store.
Posted on Aug 11, 2008
Pen exploded in dryer, blue ink all over inside of dryer, how do we remove?
The best way is to use paper towels and alcohol or hair spray. DON'T scratch the metal with an abrasive or you will damage the painted surface.
Jun 18, 2011 | Whirlpool Dryers
A pen exploded in the dryer and I cannot remove the ink from inside the drum.
Hello 5.....
  1. Turn the dryer off and remove any laundry from inside the drum.
  2. Unplug the dryer.
  3. Dampen a paper towel with rubbing alcohol.
  4. Scrub the ink stain with the dampened towel. Repeat, if necessary, with a fresh towel dampened with rubbing alcohol, to remove all the ink.
  5. Wipe the area with a cloth dampened with water, to remove any alcohol residue.
  6. If the stain persists, soak a white rag with rubbing alcohol or hairspray and scrub the stain. It may take repeated applications to dissolve the ink. Joe
Thanks for choosing Fixya!
Mar 08, 2011 | Amana Dryers
Somehow a ball point pen went into the dryer. I now have ink on the inside of the drum. What can I do to get the ink off the drum. It should be noted that the dryer weny through a complete cycle before...
You may have to experiment with solvents to find one that will remove the bulk of the ink. Start with rubbing alcohol, then try a mineral spirits (paint thinner) or WD-40 oil, and finally some acetone. Make sure there are no sparks or fire nearby while using these solvents. Be sure to clean the areas with a spray cleaner after any success to remove a lingering smell. You may have some permanent stain left that will just have to wear off, but shouldn't affect your clothes. Hope this helps!
Dec 11, 2010 | Whirlpool Dryers
Hello,i was washing my cloths the other night and a pen happened to be one of my pockets. The pen didn't explode in the washer but it did in the dryer. It ruined some of my cloths which is no big deal.The...
Hairspray is an excellent solution to the ballpoint pen ink problem. Buy the cheapest you can find and spray, let the spray sit on the spots for a few seconds and wipe with a paper towel. Keep doing this until the spot is removed. This also works on fabrics as well. As a former teacher, my red grading pen ruined several of my white shirts. I used my husband's $1.29 can of hairspray and saved over $100 in garments. He was pretty angry about my using all his hairspray but when I pointed out the money saved by not having to purchase new blouses, he relented. I keep a can of hairspray in my laundry room at all times.
Nov 04, 2010 | Hotpoint NBXR463EBWW Electric Dryer
INK PEN IN DRYER INK MARKS ALL IN DRYER HOW DO REMOVE INK
use a cotton ball with a small amount of Eucalyptus oil and wipe clean.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Whirlpool GEW9250P Electric Dryer
The inside of my dryer is turning blue!
It sounds like a fountain pen may have exploded in there. If the drum is blue from something like ink, the best stuff I have used to remove ink from a dryer is some stuff called "Goo Gone". You can find it at department stores like Wal-Mart, etc. Hope this helped and best wishes.
Aug 15, 2009 | Dryers
How to remove ink from dryer
None of the chemicals you describe should be used. The heat or spark from the motor could cause a explosion.
Put some old laundry material in there and run it multiple loads with no heat it will eventually wear it off.
Apr 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Ink in the dryer
Rubbing alcohol will work to remove most of it if you use alot of elbow grease.
What I found worked the best and quickest was a Mr Clean Magic Eraser wetted acetone nail polish remover. Leave the dryer door open to let it air dry, then put a couple of white towels soaked in bleach water and run the dryer on a non-heat cycle to remove any remaining smudges.
To be paranoid, I then ran the same towels through the washer and dryed them on high heat to make sure there was no ink I missed that might ruin any further clothes.
Mar 28, 2008 | Roper REX4634KQ Electric Dryer
Ink in Dryer
wet towel add about 1/2 cup of bleach, put in dryer.... the ink completely gone in less than 10 minutes
Sep 28, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
