My usb flash drive has stopped working. It shows up in Windows as a drive but wont let me format it or copy anything.
    Scholar:
  • 101 Answers
If it gave the drive a drive letter, you can try this:
Start> run > "CMD" (press enter) > type: "chkdsk /r X:" (press enter)
Replace X with drive letter for thumb drive. This will check the disk and repair any errors that are found. If this fails, the drive is bad and there is nothing more you can do without professional software.
Posted on Aug 11, 2008
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
My USB flash drive is not recognizable in any computer. It will give me a couple of codes..... Currently, this hardware device is not connected to the computer. (Code 45) or Windows has stopped this
Have you formatted this usb flash drive?
If you still want to get back all stored file, you'd better never format this drive, for the formatting process may erase everything on this drive. So, I hope you've not formatted it yet.
Here are some ways for you to save back your inner data and this hard drive:
1). Do not format this drive till you've saved all your stored data back.
2). Do not add any new file on this drive in case that anything new would rewrite your original data.
3). If you really know a little about data recovery things, you can directly apply some highly-recommended data recovery freeware online, such as Disk Drill https://www.cleverfiles.com/usb-flash-drive-recovery.html
4). Do not save the restored data on the same drive in case of data recovery failure.
5). Do not forget to format this drive after the data recovery process so that you can check whether this "not formatted error" problem could be resolved.
Best wishes!
Mar 02, 2017 | Verbatim ® Store `n` Go USB Flash Drive,...
Hello, i am not able to format my transcend 8gb pen drive. whenever i format this pen drive after a few second's i got a message "WINDOWS UNABLE TO FORMAT". Properties shows used space 0 bytes and free...
Try it on another usb port..or If the windows can't format try formatting it from the command prompt if it's not working than must be pendrive.. i think there's no problem with other pendrives.. or the one that you have
Aug 18, 2010 | Computers & Internet
Drive wil not allow coping with 1.8 GB open
Not sure why it won't copy anything to the drive, but you can try formatting it and then copying to it once the format is finished.
Plug the device in, then open "My Computer" and right click on the drive letter that is assigned to the flash drive, then click "format" and leave all the options alone.
A quick format should be all that's necessary. If this doesn't work, I'll have to let another Expert take over.
Dec 31, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Sandisk 8GB Cruzer Gone Dead
As long as it shows in Disk Management in Windows, it is most likely saveable. Borrow a flash drive from a friend, GHOST it to your hard drive and then to your flash drive (Drive to Drive may be unsafe because you can mix up which is which). It should work and then you can reformat it so as not to steal your buddies stuff.
Jun 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cannot format 400gb usb flash drive
I had the same problem.
Go to the Dos Prompt via run cmd
format d: or whatever your drive letter is.
This worked for me.
PS these flash drives are copies and are made in China. I just bought one for $7.50 Yes that is seven dollars and 50 cents.
Apr 21, 2009 | Electronics - Others
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 28, 2008 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Doesn;t taking large files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
Jun 19, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
RAW FS TO FAT 32
i recently bought a sony flash drive SSK/2GB.however the same is not working at all as it is showing RAW file system instead of FAT 32 .neither it is getting formatted nor allowing anything else to b doneto it.
Nov 11, 2007 | Electronics - Others
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
