Question about Kitchen Ranges
Flavel Milano 100
Grill & Fan oven stopped working today - everything else fine - i know 2 ovens fastened together, so have they seperate fuses or any other easily repaired parts ?
  • 6 more comments
  • brassneck Sep 10, 2008
    yep, I have the same problem. Cant find any trace of flavel cookers on the internet. When i have a minute i am going to pull the back off the cooker and see if its a fuse or something.
  • gwvaleting Nov 10, 2008
    i also have the same problem on my milano 100 which is 18 month old!!just wish i knew how to fix it.
  • tinkydo Dec 03, 2008
    Yep this has happened to me too. Everything was fine, then suddenely the fan oeven and grill stopped working at the same time (half way through cooking dinner od course!). Needless today the guarantee was out! Got a cooker repair chap in today, but as it has a gas hob, he cannot touch it. Got gas chap coming out Monday, but he doesn't know if he can do any thing either cos its the Electric oven !!!
  • Anonymous Feb 07, 2009
    I also have a flavel milano 100. Yesturday my fan oven and grill just stopped working!! The standard over still works. Has anyone been able to find a reason yet?
  • Anonymous Feb 20, 2009
    same problem, yesterday half way thropugh cooking some cakes oven stopped working and the grill static oven still ok though usless for cooking cakes in, has anyone found a solution yet?
  • Anonymous Mar 25, 2009
    yep same here!!
  • Hazel long Jul 14, 2013
    Hi my grill is still working bit the oven has stopped any ideas please
    Hazel. Hi my grill is still working but the fan oven stopped working today any suggestions please
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Posted on Aug 13, 2009
  • mariemartin3 Sep 22, 2011
    hi thanks is the fuse under the hob or behind the cooker
Hi ive got a milano 100 cooker and the left hand fan oven comes on but doesint get hot any ideas what this could be? I phoned flavel and they want 100 just to come out. thankyou
Posted on Jun 21, 2010
If your Left hand side of the cooker ( Fan Oven & Grill ) Has Just stopped working it is probably your timer set wrong, First check your instructions as to setting it If you can't find your Booklet Just switch of your cooker at the mains for a few seconds this will reset your clock and the oven & grill should work ok.
Posted on Feb 21, 2010
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
How do i repair my flavel aspen 100. clock and standard oven have stopped working but ignition and fan oven are both working
The printed circuit board comes as a complete unit. Contact the manufacturer if not try ebay.
Oct 01, 2014 | Ovens
Flavel milano e60 electric cooker
Element or switch is done. Try switching elements first to see if that is it....if not then the switch is gonzo. The switch works as a potentiometer allowing more or less electricity (current) through the element.
Dec 02, 2013 | Ovens
Flavel cascade 100 fan oven not heating, but fan still going. Grill and other oven still work. Is the oven lamp in the circuit? That has blown so just wondered if the two things are linked?
Heating element has blown IRCA Type RL6 1800W Remove back panel unscrew 2 screws remove the 3 conected cables open oven door remove 2 screws at rear of oven that holds faceplate in place remove face plate and take old element out and replace with a new element
Oct 08, 2013 | Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
Flavel milano 60 manual
Keep in mind that Flavel Ovens are built by Leisure CP. This link could helpfull: upl/26348-Range60Leaflet.pdf
If this information isnt help, this and other manuals could be find sending a request here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 17, 2011 | Ovens
Does anyone know where to order a thermal trip for a Flavel milano 100 cooker. The right hand oven has stopped working and I have been trying to find the spare part to no avail. Cheers
The following address has a list of sites that sell oven parts:
<a href=""></a>
Feb 14, 2011 | Toaster Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
Sep 05, 2009 | Ovens
Flavel 100 finesse problem
I have a Flevel 100 and wish I had checked out all the problems everyone is having first as I would never have bought it...what a waste of money...already replaced the element on it...the ordinary cooker died weeks the fan one has died leaving me with no means of cooking in an oven...this is going to the nearest dump as soon as I can get to the shop to buy a very cheap standin...Flavel I hope you are ashamed!
Apr 22, 2008 | Ovens
Kitchen Ranges Logo
4,155 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
