Question about Dishwashers
GE Profile Dishwasher Model GSD5630D01WW. How to reset. all lights come on and off when start/reset button pushed.
SOURCE: GE Profile Dishwasher PDW7300 Died on me!
Turns out the folks who installed it did a shoddy job of connecting the power. The power connections were not twisted on tightly enough, and after time, the continuous arcs of current between the loose connections burned through the wire nuts and finally separated the poorly twisted electrical wires. SOLUTION: Turned off power to the dishwasher, chopped off old, burned up wire ends, stripped some insulation off, twisted/spliced the electrical wires back toghether TIGHTLY and then tightly closed it all with quality wire-nuts. Power came right back on! :-) Yay! The only problem is, since the washer had been sitting/dead for a week or two, the lubricating water on the motor's ceramic bearing dried up, causing the motor to seize up. Had to replace the motor. :-( But everything is working fine now!
Posted on Apr 18, 2009
SOURCE: GE profile performance dishwasher- not starting after child pushed buttons.
This is the correct solution. Just happened to my touchpad dishwasher. While I was waiting for it to reset I thought I'd go online to see if there were any other solutions should this one not work. After waiting 15 minutes I turned the breaker back on and Viola! Back in business.
BTW, workes for frozen televisions, too. :)
Posted on Feb 25, 2010
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
MNTECH
  • 1543 Answers
SOURCE: GE profile PDW9280J00SS dishwasher. It
Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
Posted on Feb 06, 2011
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Built In Dishwsher won't start when you push the start
I turned off the power to the dishwasher for 10 minutes as recommended by a serviceman via the phone and then turned it back on and it reset itself and worked fine.....
Dec 26, 2008 | GE 24 in. Profile PDW7800 Built-in...
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE Profile built in dishwasher problem
Try cutting the breaker off for 5 min, This will reset the control.
Mar 14, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
245 people viewed this question
Top Dishwashers Experts
