Question about Apple iPhone 3G
Sim Card Can not slide back off to fit sim card
  • 1 more comment
  • Anonymous Aug 15, 2008
    How do I put the sim card into my new i phone
  • Anonymous Sep 08, 2008
    I just bought an iPhone and I simly cannot find a little tool to use to slide a sim card out. Does anyone have a picture? or a VERY detailed description?
  • Anonymous Dec 25, 2008
    i have no tool and i cant slid the back off how else can i put my sim card ino my new iphone 3g
  • 4 Answers
Stop!
The back does not slide off.
Use the small tool in the box to depress a very small plunger on the top of the iPhone 3G, next to the earpiece socket.
A drawer will open to insert your Sim.
Regards
Philip G0ISW
Posted on Aug 13, 2008
2 Suggested Answers
  • 33 Answers
SOURCE: wont read my sim card
you might need to get a new one.
go and stop by at a tmobile retail store
and have them transferr all your infos
out of your old sim card onto a new one.
good luck. and hope that help
and dont forget to rate it!
thanks.
Posted on Jul 26, 2009
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
How do you put a sim card in
Depending on the Phones Make and Model and what type of SIM card you are NEEDING if SIM card didn't come with PH?
You can go online and look at diagrams of the Various SIM cards. Most SIM card fit Behind the Battery of your Smart PH. You must carefully remove back of ph most smart phone have a small indention to assist with removal? If not either use your nail or THIN OBJECT (Fake Nail Tips Work Great, Even your Nail, plastic/Wood Tooth Pick or any thin enough non metal to open seal ) Then carefully remove back of ph then Battery the SIM card slot will either be on the side or Top or bottom behind Battery space Slide Sim card in with Metal connector sides down in direction indicated then replace battery and back of ph. Some Phone come with a Internal SIM Card for Programing of phone, the other SIM card Slot is for Memory make sure if this is what is NOT Situation your PH? Some even have Duel SIM Slot they Usually can be programed with either type of SIM Card Purchased these are for the new I call Free-agent Phone meaning you Purchase your Phone and Choose your Carrier Such as Straight Talk ect.
Apr 01, 2017 | Cell Phones
I need to replace the sim card
In almost every cellphone the Sim Card is located under the battery. Open the back of your phone where the battery is located and remove the battery. You should see the Sim Card that you want to replace. Most Sim Cards slide under a small holder. Gently slide the Sim Card out. Make sure that you are aware of how the old Sim Card is positioned so that you can simply slide the new Sim Card in exactly the same way as the old Sim Card came out. Replace the battery and close the back cover and you are finished.
Oct 05, 2012 | Motorola Mobility V950 Cell Phone
Water damage
1. Remove the back cover of your phone. To do so, you will have to press down on the silver latch while sliding the cover off toward the top of the phone.
2. Remove the battery from inside of the phone. Be sure to place it somewhere where it will not be damaged. Locate a silver hatch; this is where the SIM card is stored.
3. To undo the silver hatch, slide it in the direction that says "Unlock." Then, flip it upwards so that only one end of it remains attached to the BlackBerry. Carefully remove the SIM card.
4. Replace the SIM card after a few seconds. It should fit back into its place in the exact same way you found it. Lock the silver hatch by laying it back down over the SIM card, and then sliding it the opposite way you had unlocked it before (to the side that says "Lock"). Put the battery back in as well (by fitting one end at a time). Replace the cover (make sure the silver button latches).
5. Turn the phone back on. The "SIM Card Error" message should be gone.
Aug 17, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
Can you please advise me on removing the back to fit my new sim card Regards
To remove the battery and/or cover from the phone, follow the steps and diagrams below:
To remove the cover, lift up (1) press and slide the section of the phone upward.
Installing the SIM card, make sure the gold contacts of the SIM card are facing down before attempting the insertion. Slide the SIM card into the SIM card socket.
Note: The data stored on the SIM card can be damaged if the card is sctrached or bent during installation, so be very careful when installing the SIM card.
Slide the battery into the compartment so that the tabs on the end align with the slots at the bottom of the device and the metal contacts line up with the those on the device. Lightly press down on the battery until it slips into place
Lastly, Place the battery cover onto the back of the phone (the tabs at the top of the battery cover should interlock in the body chassis). Lower the battery cover down until it is flush with the phone.
Thanks.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
Instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
May 05, 2009 | Nokia 2680 Slide Cell Phone
How to remove the sim card from w200i?
Sim cards are pretty hardy and it's unlikely you will damage it. Most sims now fit into a slide slot which means you need to bend the card slightly by lifting up the edge to slide it out.
Hope this helps,
erch.
Mar 15, 2008 | Sony Ericsson W200i Cellular Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Sim card-Is a i730 sim card compatible with an i560?
take off the back and take out your battery...then to the right you will see a little slot in order to slide it in all you have to do is slide the sim in whatever way it fits
Oct 05, 2007 | Nextel i730
Apple iPhone 3G Logo
91 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
