Question about Canon NP 6545 Copier
E212 Error code
My first problem was that it was printing a strip of black on the bottom of the page. I turned the machine off. Then it gave me error code E212. So I turned it on again (like it said to) and it still said the same thing. Please help me!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Posted on Aug 11, 2008
My photocopy machine doesnt work, that is once you command for printing it brings an error code of 212 (E212) and the sensor doesnt move
Posted on Nov 29, 2008
SOURCE:
This printer started printing all pages completely Black when sending multiple pages through the automatic document feeder(ADF). Huge waste of toner! No error codes. Individual pages print correctly w
First step is to update the firmware to current revision to see if that resolves the problem. Go to HP.com and search for fimware update for your printer. If sounds like the scanner head is not moving to the correct location when scanning and is just reading black strip on the bottom of the scanner bed. Have seen this issue with other models.
Sep 14, 2014 | HP LaserJet Pro 400 M425DW Mono Printer
Code error E212, with 3 options: Command card Initial detector Moving device somethig like that
E212: problem with the optical section
  1. Home position sensor is defective
  2. Motor Lens move iis defective
  3. Control board is defective
Oct 16, 2010 | Canon NP 6551 Black and White Copier
Error code 5100 on mx700 printer
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This part is related to the optical encoder which tells the print head where it is. Look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start up sequence. Softly clean this strip with a damp lint free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 28, 2010 | Office Equipment & Supplies
I get Error Code 0502. I've reset the little
Hi there
Ok try this and see if it will do it
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 14, 2009 | Dell A940 All-In-One InkJet Printer
Hp 3310 all-in-one injet spilling black inside unit
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jul 07, 2009 | HP Photosmart 3310 All-In-One InkJet...
HP 3310 all-in-one printer spilling black ink inside unit
Hi ok gave it a go I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Brother MFC-9840CDW. Print unable 29 error message. What do I do???
I got this error today. After examining the drum unit I saw one of the 4 drums (cyan) had a strip of sticky plastic wrapped around it, preventing it from turning easily. The plastic was from the drum unit itself. It held the cyan wiper pad in place. My drum unit needs to be replaced after 3300 pages. It was supposed to last for 17,000.
I have pulled out the color toners and am using it with only black until I get a replacement.
Jan 14, 2009 | Office Equipment & Supplies
Error code
Hi You can Try gave it go
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Sep 12, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Error code E212
sorry I have'it only in italian
Jul 11, 2008 | Canon NP 6035 Copier
CANNON NP6025
E212 is scanner home position error.remove the platen glass. Check the scanner and lense assembly.
Sep 01, 2007 | Gestetner DSc224 Copier
Canon NP 6545 Copier Logo
478 people viewed this question
Clive
Clive
old marine
old marine
Ekse
