Question about Maytag Neptune MDG5500AW Gas Dryer
IGNITOR How do you access the ignitor to replace it?
To get to the ignitor, you must remove the front panel. To do this, first open the door and remove the two screws and plastic tabs that are directly across from the door hinges (left side if rt hand swing door and right side if left hand swing door). Next, support the door and remove the two screws from the hinges and remove the door. The front panel is now loose and will pivot down from the top out. Pull it out a couple inches then straight up and out of the way. You now have access to most all of the components internal of your dryer, including the ignitor. I know it's late, but didn't see an answer for it yet....and I have mine apart right now for the same problem (runs with no heat).
Posted on Oct 06, 2008
Oven works but when you open it to check stuff it loose temp fast and starts to try ignighting
Sounds like a weak ignitor to me. Remove the bottom panel on the inside of the oven. This will give you access to the ignitor. Use a multimeter set to measure amperes and clip the clamp end around one of the wires turn off the gas in the rear of the oven. A normal ignitor would draw 3-3.3 amps or higher any less then this would constitute a weak ignitor and should be replaced. Yes this does mean at 2.9 you would also replace the ignitor. A weak ignitor takes much longer to light the gas in a unit. If you have any further questions message me back. Thank you
Rick
Nov 30, 2011 | Ovens
Oven won't heat but burners light #jgbp28eek3db
Most likely its your electric ignitor. Remove racks from your oven. Remove the bottom plate in stove and it gives you access to the ignitor. Turn the oven on and see if your ignitor glows. If not replace ignitor. If it does than check the amperage going from ignitor to to gas valve. If you have anymore questions Please feel free to comment me.
Jul 29, 2011 | GE Kitchen Ranges
How do you access the ignitor on amana oven acf3375ac? Is access from with in the oven compartment?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | Ovens
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
The ignitor is working but it is not heating up?
The ignitor could be glowing and still be bad. You will have to remove the oven racks and the base cover in the oven to access the ignitor. Place a clamp on amp meter over one wire of the ignitor and turn the oven on. If the meter reads 3 amps or less,replace the glowbar ignitor.
Nov 09, 2009 | Ovens
The oven comes on but won't heat up
Replace the glowbar ignitor. Remove the oven racks and then the bottom base pan in the oven to access the glowbar ignitor.
If you have a volt/amp meter place the clamp on amp meter over one wire of the ignitor.Turn the oven on. If it reads less than 3 amps,replace the ignitor.
Nov 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Replacing oven ignitor in Amana AGDS901WW
The ignitor can be replaced through the oven. When you take it loose, If you cant find the plug just cut the wires and wire nut the wires together with the porcelin wire nuts provided with the ignitor.
Nov 21, 2008 | Kitchen Ranges
Oven won't light on bake
IF THE IGNITOR GLOWS WHEN YOU TURN ON THE OVEN, BUT DON'T GET ANY FLAME, IT IS MOST LIKELY THE IGNITOR. THE COST OF IT IS AROUND 50-75 DOLLARS.
TO REPLACE ONE, YOU MUST GAIN ACCESS TO THE OVEN
BAKE BURNER BY LIFTING OUT THE BOTTOM PAN OF THE OVEN. THEN REMOVE TWO SCREWS THAT HOLD THE IGNITOR TO THE BURNER. FOLLOW THE WIRES DOWN TO THE CONNECTOR PLUG. SELF-CLEAN MODELS WILL BE BEHIND A PANEL BEHIND THE STORAGE DRAWER. NON SELF-CLEAN MODELS WILL BE BEHIND AN ACCESS PANEL DOWN IN THE BROILER AREA. DISCONNECT THE PLUG AND REPLACE THE IGNITOR IN REVERSE ORDER.
PART NUMBER 12400035 MAYTAG.
Mar 31, 2008 | Kitchen Ranges
Maytag Neptune MDG5500AW Gas Dryer Logo
125 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
