Question about Dell Dimension 2400 PC Desktop
DVD installation Installing a sony dvd. How do I remove the case?
    Scholar:
  • 152 Answers
It's a very easy process. But first, is it compatible with your pc and your operating system? Generally, you will have to remove one side panel from a desktop pc. Be sure to unplug the computer before you take the cover off. Touch the cover that you just removed to discharge any static from your body so you don't damage your system. Find an open bay (you will have to pop out the front cover - it's easy to do) and insert the drive. Connect it to the power supply. Before you put the side cover back on, plug in the pc and boot it up. You should get a message that new hardware was found. Use the install disk and you will then be able to use your drive. You can then put the cover back on. You don't have to shut down to put the cover back on. Just be careful that all of the wires and such are inside and not hanging out when you put the cover on. Piece of cake.
Posted on Aug 22, 2008
I have e machines EL1300G-02W desktop pc has dvd rom can i add a cdrom drive?
Your DVD-ROM drive will also play CD's. You can also easily remove it and replace it with a CD-ROM drive if you like. Simply open the case, unscrew the DVD-ROM, remove the power and data cables from the back and pull it out through the front of the case. Installing the CD-ROM just involves doing this in the reverse order. Make sure your computer is off and unplugged during this process.
Mar 05, 2011 | E-Machines eMachines Desktop PC
My Sony DRU-810A DVD RW Dual Layer Burner cant be detected by my pc.. is that it need to be installed the driver first or what?
You can try installing the driver first ,but you can also try just installing the drive then reboot and go to this link http://www.fixya.com/support/r5003649-find_24_trubleshooters_in_windows7 looking about half way down,you'll see a tool for fixing that drive.
Good luck.
Please rate my sollution.....
Jun 02, 2010 | Sony DRU-810A DVD RW Dual Layer Burner
Installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
How to install a second dvd player in my compaq
The computer needs to be opened up to properly install the CD or DVD drive into the computer. The method for opening the case will vary depending upon the case. Most new systems will use a panel or door on the side of the system while older systems may require the whole cover be removed. Remove and set aside and screws fastening the cover or panel to the computer case and then remove the cover.
Computer cases can generally hold a number of external drives but only a few are generally used. Any unsed drive slot has a cover that prevents dust from entering the computer and makes the case look better. To install the drive, it will be necessary to remove a 5.25" drive slot cover from the case. Removal of these generally is done by pushing some tabs either on the inside or outside of the case. Some may be screwed into the case.
The majority of all CD and DVD drives for computer systems use the IDE interface. This interface can have two devices on a single cable. Each device on the cable must be placed into the appropriate mode for the cable. One drive is listed as the master and the other secondary drive is listed as a slave. This setting is generally handled by one or more jumpers on the back of the drive. Consult the documentation or diagrams on the drive for the location and settings for the drive. If the CD/DVD drive is going to be installed on an existing cable, the drive needs to be set into the Slave mode. If the drive is going to reside on its own IDE cable alone, the drive should be set to the Master mode.
At this point, the CD/DVD drive needs to be placed into the computer. The method for installing the drive will vary depending on the case. The two most common methods for installing a drive into a case is either through drive rails or directly into the drive cage. Rails: Place the drive rails onto the side of the drive and fasten it with screws. Once the drive rails have been placed on both sides of the drive, slide the drive and rails into the appropriate slot in the case. Make sure to affix the drive rails so that the drive is flush with the case when it is fully inserted into the case. Drive Cage: Slide the drive into the slot in the case so that the drive bezel is flush with the computer case. When this is done, fasten the drive to the computer case by placing screws into the appropriate slots or holes in the case.
Many people use the CD/DVD drive inside of their computer to listen to audio CDs. In order for this to work, the audio signal from the CD needs to be routed from the drive to the computer audio solution. This is typically handled by a small two wire cable with a standard connector. Plug this cable into the back of the CD/DVD drive. The other end of the cable will plug either into a PC audio card or motherboard depending upon which the computer uses for audio. Plug the cable into the connector labeled as CD Audio.
At this point, the CD/DVD drive needs to be attached to the computer through an IDE cable. For most users, the drive will reside as a secondary drive to the hard drive. If this is the case, locate the free connector on the IDE ribbon cable between the computer and the hard drive and plug it into the drive. If the drive is going to be on its own cable, plug the IDE cable into the motherboard and one of the other connectors of the cable into the CD/DVD drive.
The only internal item left to do for installing the drive is to plug it into the power supply. This is done by locating one of the 4-pin Molex connectors from the power supply and inserting it into the power connector on the CD/DVD drive.
At this point the drive is fully installed into the computer case so it can be closed up. Replace the panel or cover to the computer case. Be sure to fasten the cover or panel back to the case using the screws that were set aside when the cover was removed.
All of the installation steps for the CD or DVD drive are now completed. The only thing left to do is return power to the computer. Plug the AC cord back into the power supply and be sure to flip the switch to the on position.
Regards..
Apr 09, 2009 | Compaq Computers & Internet
I want make my PS3 play any region dvd
The only way to currently do this is to remove the region coding. You can do this by installing a program called cloneDVD4, it will make a 1:1 copy of your dvd while removing any regional settings. This is not illegal as long as you have purchased the DVD and are not renting/borrowing. Be sure to burn the copy of your DVD to a DVD-R and NOT DVD+R.
Jul 25, 2008 | Sony Playstation 3 (PS3) Console
Installing standard third-party optical drives in VAIO PCV-650 case
Hi there. I've worked for Sony VAIO and can assure you that the only solution is to get a Sony Branded Spare parts. The parts of Sony VAIO are very specific. As of now I see that the only solution for you is to either contact Sony Service Center or go for an external DVD Drive.
May 16, 2008 | Sony VAIO Digital Studio PCV-RX650 PC...
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Corrupted or missing?
Did you try re-installing your operating System ?
mike @ Compurepair.
Nov 10, 2007 | Sony COMBO |CRX850E SLIM % (CRX850E)...
Dell Dimension 2400 PC Desktop Logo
59 people viewed this question
Alun Cox
