Question about Sony Handycam DCR-DVD108 DVD Camcorder
Cannot see DVD
I recorded a DVD half way through.  I reviewed what I had recorded, then continued recording on that same DVD.  I reached the end of the DVD, took it out of the camera, put in a new one, and continued recording.
When I tried to finalize the first DVD, the camera said that option was not available, and I cannot see the contents of the DVD in the camera or in any other device (computer, DVD player).  However, when I insert the DVD into my laptop, it says that there are 1.34 Gb on the disk information, but the files inside the DVD only have 32Kb each.  Somebody said something about having a double session on the same DVD, and that that was the reason why I couldn't see it.
Could this be true, and if so, what can I do?  What's recorded on the DVD is very precious to me, and I don't want to lose it.
  • 1 more comment
  • Anonymous Aug 28, 2008
    yes, having same exact problem, same circumstances.
  • abc137 Sep 01, 2008
    Same issue. Any solution?
  • ravic Sep 06, 2008
    same problem
  • 10,594 Answers
Try to finilize your DVD in another Sony camcorder.
Posted on Aug 11, 2008
Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Jun 09, 2014 | Philips Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Pre-recorded dvds used before now will not load?
Since there are no firmware updates for this device, the lens is either dirty or defective. Unfortunately, the reviews for this product aren't very good. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r135/4505-9141_7-31778396.html
Hope this answers your question. Best of luck.
Greg
May 28, 2009 | Samsung DVD-R135
Sanyo DVD recoder doesn't play if I let record run to end of disk
most dvd recorders have setting to finalize at the end of a timer generated recording, or to fianalize when the disc reaches the end and runs out of room, check for one or both of these settings in the setup menu of the recorder
Mar 31, 2009 | Sanyo DRW-500 DVD Recorder
Ilo dvd recorder do not recognize any dvd
According to www.dvdrhelp.com that this unit is very picky on what discs it will record on. Look up unit and read the large number of reviews in DVD Recorder section
Dec 25, 2008 | iLO DVDR05 DVD Recorder
The best dvd recorder to with my dvr
hi evguess,few things to look in your dvdr is that it should record major formats.it should have a FireWire connection for DV camcorder hookup.and relatively painless operation and ofcourse sould have all the spares avalable on your local market.
ive got a few options the best available dvdr.
1)philips dvdr80.
2)lite-on LVW-5005
3)DMR E50K (THIS MODEL DOES NOT HAVE A FIREWIRE BUT ITS THE LEAST EXPENSIVE MODEL.
hope this help to reach your requirement.
plz rate it if this review helps u.thanks..
May 11, 2008 | Televison & Video
Recording problem with LG DR275
Make sure your machine is well ventilated, mine had an overheating problem.
Apr 26, 2008 | LG DR275 Recorder
Humax Tivo will not record to DVD
www.funai.us
Customer Support Representatives may also be reached by telephone at 800-242-7158
Oct 28, 2007 | TruTech TT1620 DVD Recorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
