Question about HP Photosmart 325 InkJet Printer
Image is partially cut off when printed
I'm trying to print a photo from the computer to my hp 325. When it prints, there is a white border only on one side and on the bottom that means the image I want is chopped off. I don't want a border at all. But, setting up for a borderless 4x6 print still resulted in the same outcome. Please help! I'm trying to print a photo to give as a birthday present tomorrow.
Sylvia Hardin
gshardin@cox.net
Your expert patiently talked me through several possibilities. Finally, in the print set-up window, I clicked on Properties in the upper right and made all my printing choices there. I still got a border, even though I didn't want one, but it was all the way around the photo...not on two sides, and the photo was not chopped off.
Posted on Aug 12, 2008
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Photo printing
Try, under Printing Preferences, Effects, check settings for "No Borders" or select a higher % of normal size.
Feb 25, 2014 | Hewlett Packard Printing & Imaging HP...
Kodak 6850 how do I print 4x6 on 6x8 paper without huge white border... now that you cant buy 4x6 media ?r
the 6'' paper is not the problem at all, you might need to crop the image to 4x6 size before printing since most point and shoot camera will not take the photo 4x6 size but 4+ inches, thus the border. richard
Nov 22, 2010 | Kodak Photo Printer 6850 Thermal
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Why does the top of my picture cut off when i print it
Ladydiw,
Are you trying to print the image to the full size of the paper if so does you printer support edge to edge printing?
If not or if you are unsure try resizing the picture to leave a border round the edges.
Regards
Nick
Oct 26, 2008 | HP Office Equipment & Supplies
Printer lines in photo's
Click Start - All programs - HP - HP Solution center.
In HP solution center Click on the Printing Shortcuts tab. Select Photoprinting with borders or borderless. Click OK.
Then close the HP solution center. Try printing. Print photos always with Best quality.
If the issue persists check the ink level of both cartridges and use Photos Cartridge HP 58 to print photos. We insert the Photo cartridge in place of black cartridge.
Thanks
Dec 19, 2007 | HP Officejet 5610 All-In-One InkJet...
Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP Photosmart 325 InkJet Printer Logo
206 people viewed this question
Ben Johnson
