Question about Toshiba MD13Q41 13 in. TV/DVD Combo
Describe your Toshiba MD13Q41 13 in. TV/DVD... Problem
No sound
  • tracyworks Jan 07, 2009
    VIDEO AND SOUND RUN ON RCA PIICTURE GOOD BUT NO SOUND I HAVE TWO OF THESE UNITS THEY BOTH NO SOUND I HOOK A DIFFERENT MONITOR UP TOSAME CONNECTIONS AND IT WORKS PERFECT
Power light comes on for a second then shuts off
Posted on Oct 21, 2008
Toshiba tv has no sound but does with DVD player on, how do I regain sound for tv shows
is the dvd player a home theatre system?if yes,does the tv play sound via the dvd home theatre speakers when it is on?if yes then maybe you should double-check your audio port connections between the two for correct configurations
Jan 04, 2016 | Toshiba Televison & Video
After tv is on for about 4 hours- sound becomes distorted. it has to be turned off then back on agian to restore normal sound..it has been happening since we got tv- which was only 6 months ago
Take it back where u buy it,talk to the store for a replacement,if possible.Or call Toshiba,talk to customer service,describe the problems,ask for a warranty repair.The Tuner board is is the board where the coalax broscast tv signal comming in to this board.It have faulty componnents on it.The board should be replaced.So get the tv replaced buy the store or waranty repair by Toshiba.
Jun 12, 2010 | Toshiba REGZA 47HL167 TV
All of a sudden the sound just quit on my Toshiba SDK990 DVD player. Any ideas? TV works fine and have checked different audio settings and cords and all.
First: be sure the TV sound is ok. then, try the DVD sound by using headphones. If it sounds, then try moving by do a little pressure aside the audio connector from DVD to TV while it is connected
Apr 20, 2010 | Toshiba SDK990 Player
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Sound fades in and out when playing a dvd on Toshiba TV
1. This is due to a failing sound module
2. Your flat panel tv needs service to the board level to check voltages and components surrounding the sound chip in your tv.
Dec 31, 2009 | Televison & Video
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
No sound when playing dvd
HDMI may not output sound. Go into the setup screen of the DVD player and go into audio setup. Make sure you have it set for PCM or equivalent DIGITAL setting. If you set that and you still get no surround sound, you will have to use and optical cable between the receiver and the DVD.
Sep 06, 2008 | Audio Players & Recorders
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Toshiba MD13Q41 13 in. TV/DVD Combo Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
