Question about Brother Office Equipment & Supplies
I have replaced all the ink cartridges as it said even the ones that werent empty now just to see if it would help have turned off the machine and back on it still reads replace the ink cartridges and says there are no cartridges install cartridges its only 4-5 months old?? suggestions?
    Master:
    Sergeant:
  • 398 Answers
Did you use original equipment cartridges? Many times the printer will not recognize after market or reconditioned units.
Posted on Aug 11, 2008
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Near empty black is displayed even with new black cartridge
If you replaced an ink cartridge while Near Empty was displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes 2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand new one, please be sure to select 2.
WARNING
If ink gets in your eyes, irrigate them with water immediately and call a doctor if you are concerned.
If you wait until Ink Empty message is displayed on the LCD, the machine will automatically reset the ink dot counter.
If the Install message is on the display after you have installed ink cartridges, check that the ink cartridges are
installed properly.
Jan 01, 2011 | Brother IntelliFAX-2440c Plain Paper...
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
(Yes) to automatically reset the ink dot
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
Printer claims black ink cartridge is empty, but it can't be.
Se if the tape, that comes with a new cartriage is of the cartriage if not try a new cartriage if the does not work your machine needs service
Jun 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
