Question about Epson Stylus Pro 4800 InkJet Printer
Epson 4800 Registration Issues
I'm using this printer for screen printing and have recently had trouble with lineing up all my images using the registration marks. Epson says it's the film. At first they thought it was a head alignment issue, but then retracted because I'm only printing one color. My screen printing supplier had me adjust my platten and suction, which didn't work either. I'm at a loss and would love some help!!!
  • Progboy Nov 20, 2008
    Separations are not lining up especially when using the reg marks.
    Did you find a solution?
  • 33 Answers
Are you sure that it's not Photoshop related?
Posted on Nov 19, 2008
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson R300 printer, need to print a mirror image
Hi
open printing preferences and page layout . At the top it says more options, just tick mirror image.
Mark
May 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Film postives for screen printing
Try running the film through the printer with no image before imaging with graphic. The film will be "pre shrunk" so that when the image is actually printed on the film, the shrinkage will be minimized. This should work unless it is a roller slippage issue.
Jul 11, 2008 | Xante Accel-a-Writer Laser Printer
Printing onto clear film for screen printing film positives from R2400
midwest screen and supply will have the printers and the films for screen printing, it's the company i go through and i've had no problems in the past 14 years of ordering from them
Apr 18, 2008 | Epson Office Equipment & Supplies
Epson 1800- trouble printing cds
Try to print on a sample or spare CD, before that Click Print Position Confirmation Pattern in the Print Confirmation Pattern section.Click Print to print the confirmation pattern on the disc and remove disc..
--Using a metric ruler, measure the distance from the hole to the cross marks labeled A and B. On print cd application click file and click print and select adjust print position, click enter values then select the distance for A into the height (top) box and distance for B in the width (right) box then click on ok
Mar 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Duplex Registration
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and locked print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
SP1-XXX (Feed)
1 Mode No.
(Class 1, 2, and 3) Function / [ Setting ]
1-002
[S-to-S Reg.]
Side-to-Side Registration
1 By-pass Table *
2 Paper Tray 1 *
3 Paper Tray 2 *
Adjusts the side-to-side registration by changing
the laser main scan start position for each mode.
[ -10.0 to 10.0 / 0.0 / 0.1 mm/step ] FA
4 Paper Tray 3 *
5 Paper Tray 4 *
6 Duplex *
Feb 06, 2008 | Ricoh Aficio AP3800C Laser Printer
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
Nov 18, 2007 | Canon PIXMA iP90 Mobile Printer
Epson 2200 printing problem
More a software problem it imaging try reloading the software[driver] and do it exactly as Epson tell you - disable A/N program for example.
Jul 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus Pro 4800 InkJet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
