Question about Cameras
Nikon E8800 camera
I have a Nikon E8800 camera.  The battery is charged properly; the card goes in but the camera will not turn on.  It had been functioning very well until this happened.    Your assistance greatly appreciated.  Thanks
Check to see if one of the pins inside the memory card holder is bent over. We have lost 2 of these cameras to this problem.
Posted on Sep 10, 2008
While deleting photos camera shut dow
May I suggest the battery was very low. The Nikon delete routine shows a bright display after the file is deleted, this may take a bit of power. May I suggest you work on your files on your computer? That is, that the SD card out and work on the files on the computer. Now I suggest charging the camera and taking out the SD Card and then turning it on. If it works try it again with the SD card in.
Jun 20, 2014 | Nikon Coolpix S4000 Digital Camera
Power on green light on coolpix L18 is blinking. Why? Camera won't work.
This might not work with all cameras, but try it anyway...
Take out your battery and memory card. Put them back in with the battery being first. Try and charge.
You might still have problems charging with the USB lead to the camera. In such a case, you should buy a proper charger that you can put the battery into and charge it. Sometimes charging through the camera doesn't work.
Dec 12, 2013 | Nikon COOLPIX L18 Digital Camera
Switch sim card
Your SD card is for your memory check your battery
this is what you check... turn off your camera Take out you battery charge and replace... Take out your SD card replace it correctly. Remove your lens and replace correctly then turn on camera and walla it works! PS its ok to leave the SD card in the camera. The on and off switch turns on camera with a charged battery ELEMENTRY WATSON.
Nov 19, 2013 | Nikon Cameras
My digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
My E8800 sometimes shuts off when I click the shutter
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jul 05, 2009 | Nikon Coolpix 8800 Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
I need PC drivers for Nikon E8800. Thanks
try this link from nikon:
http://nikoneurope-en.custhelp.com/cgi-bin/nikoneurope_en.cfg/php/enduser/std_adp.php?p_faqid=4657&p_created=1055346227&p_sid=T97gnysj&p_accessibility=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yNTMmcF9wcm9kcz00NjcmcF9jYXRzPTI0MSZwX3B2PTEuNDY3JnBfY3Y9MS4yNDEmcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
at the end of the page there's download button, click it and get the driver then u have to install them. good luck
Mar 02, 2009 | Nikon Coolpix 8800 Digital Camera
My Nikon D50 camera says
It thinks that the SD card is full - try re-formatting if you have no photos there. The SD functions the same as a PC hard drive, and if the directory 'tracks' are corrupt, anything could happen. Else try a new SD card.
Jul 04, 2008 | Nikon D50 Digital Camera with Nikkor AF-S...
Nikon D70
i think is power board dcdc converter board has been faulted or somewhere there is a short circuit , you do one thing remove the lens and put the camera on manual setting push the mirror upwards with finger and make on the camera if you feel a loading if not some time its main moter drive board goes else i will purchase the camera in dead condition tell me the rate thanks
Feb 28, 2007 | Nikon D70s Digital Camera
Cameras Logo
87 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
