Question about Sanyo DS20930 20" TV
Changing from video 1 to tv channels...
Hi! I left my son's remote at his Dad's house when I let him take his tv with him on his visit. Now his Dad forgot to pack the remote with the rest of his stuff and his tv is stuck on video 1. How do I change it without the remote?
    Champion:
  • 232 Answers
IF THE TV DOESN'T HAVE A BUTTON U NEED THE REMOTE, U MAY GET AWAY WITH A UNIVERSAL BUT ONLY IFNITS THE SAME BRAND MAKER OTHERWISE U MAY HAVE GET THE REMOTE IF POSSIBLE OR USE A VCR AS THE NEW TURNER FOR THE TV, WHICH U CAN USE THE VIDEO OUTOUT TO INPUT THE SIGNAL INTO THE TV
Posted on Aug 11, 2008
6ya staff
SOURCE:
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My toshiba 27a45 tv says video lock when i change it to channel three how do i unlock it without the remote
To get more details about how to unlock Toshiba TVs, visit this site ,Electro-help'.
Jun 08, 2012 | Toshiba 27A45 27" TV
Can't change channel from video 1
You might need the remote to change from video to tuner. Try buying a cheap univeral remote from Radio Shack.
Mar 16, 2009 | Televison & Video
Unlock regional video restriction
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
May 01, 2017 | Panasonic Viera TX-32LX77 LCD TV
Switching to tv
I need a make and model number. You might try cycling through the channel button after the TV is programed.
Sep 12, 2008 | Televison & Video
Most remotes have the source button at the top right hand side all the top left hand side it should be called sauce or it might just have three lines if you have a black lever on the right hand side then you need to press that in and wait it should put you to the av screen then if you let go you can press down or up that will let you chose av or video of hdmi ok if you want to send me a pic of the Tv so I could help you more if you can't find it I don't mind ok
Jul 10, 2017 | Toshiba Televison & Video
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Sanyo DS20930 20" TV Logo
138 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
