Question about 2wire HomePortal 100W (1000-400026-000) Wireless Router
Reformamated windows xp and unable to install my 2wire homeportal 100w
I reformatted my computer....I am unable to install my 2wire modem...It worked fine before I reformatted my system...so I know it isn't the hardware. The green light is no longer on either. I have run what I believed to be a 2wire driver...but I am not finding success. Please help.
  • fatdragon May 11, 2010
    is this a dsl modem only or a home gateway?
    how are you connecting to it (network cable/usb/hpna/wireless)?
You neen the driver from 2wire.com it is called twusb1405 extract to temp folder then unplug the router then plug it back in and it will look for driver direct it to the folder you unzipped it to and hey presto
hope this helps
Andie
Posted on Feb 06, 2009
I have a 2wire modem from att. i made a 50 foot eathernet cord, i have a eathernet transmitter teaster to test the cable to see if it is good (and it is) but i still cant get internet on the other side of...
Try with a shorter enet cable and see if you get internet, if you are able to get internet with a shorter cable then the cable might not be working fine. Else get a wireless card installed on your computer since the 2wire modem has wireless connectivity. It would be more easy and convenient to connect to wireless using the 2 wire modem.
Jun 24, 2010 | 2wire (1000-000057-000) Modem
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
2 other computers connected to main, signal strength very poor
oK
at the address bar type 192.168.1.254
should bring a 2 wire page
go to homenetworking
then advanced settings
will ask u for ur modem code
if u dont remember it click forgot will give u hint if u still dont know click still cant remember password
will ask u for a system key its in brackets on ur modem
10 digits will prompt to make new one
then go back to homenetworking at top of page
advanced setttings and then at the very bottom you can boost it up GOOD LUCK
rate my service please
, JULY
Apr 11, 2009 | 2wire Computers & Internet
Connected directly to my 2wire modem
You can download the driver HERE. The file is in zip format and will need to be extracted to a folder.
Click Here for instructions on how to access setup.
Jul 15, 2008 | 2wire 1800HG Router (RG1800HG00)
1800hg 2wire modem problem!
try to use another power adapter with the similar power output aside from what came with your 2wire modem if you have one, if it works fine that means the original power adapter is busted and i think it is also covered by the warranty, get a replacement from the store where you purchased it.
oh by the way, it's normal for all of the lights on your modem or router to blink when you initially power on the hardware, usually your hardware will perform a system check for several seconds to verify if there is any problem after that, several lights if not one should remain steady like the power light, the other lights on the other hand like the ethernet(LAN) or the wireless(WLAN) will most likely flicker from now and then because it indicates activity between the modem and the device/s attach to it.
Hope that answer your concern about your 2wire modem.
May 09, 2008 | 2wire HomePortal® 1800HW Router...
2 wire 1800 router on talk talk
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 27, 2008 | 2wire 1800HG Router (RG1800HG00)
2Wire USB Remote NDIS Ethernet driver
When I restart my computer I get a found new hardware message. Asking to download the driver for the 2Wire USB Remote NDIS Ethernet, or put in the installation disc. Do not have the disc anymore please help me to find the driver I need. I have 1000HW 2Wire modem. It seems that until I make this change, I cannot properly sync my Palm Pilot. Could that be true?
Apr 16, 2008 | 2wire 1000-200004-000 Network Adapter
2wire HomePortal 100W (1000-400026-000) Wireless Router Logo
124 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
