Question about Mitsubishi WT-42311 42" Rear Projection Television
WT 42311 won't power up
The tv was running when it decided to turn itself off.
Since then it will not turn on.
The error code when I pushed the input and menu buttons together is 1 flash pause 2 flashes.
  • 1 more comment
  • Casper_T Sep 19, 2008
    mine has the same problem
  • Anonymous Sep 29, 2008
    my mitsubishi 1080 is showing an error code 1 flash pause 2 flashes. can anyone please tell me what this means. thank you very much
  • virgo8244 Jan 17, 2009
    I had the same problem with a WT42311 unit recently acquired second hand and not working. According to the service manual, the error code 1blink, 2 blinks = no error detected! Strange as that sounds (since the set won't power up) I think it means that the diagnostics can't truly get to the real problem due to the set not powering up all the way. I've tried cleaning one of the circuit boards, and now my error code is 2 blinks, 2 blinks, which is supposed to mean "short protect circuit". I take that to mean I have a short circuit, the tv has detected it, and the set is turning itself off to protect itself from damage. This is more that I had before so I guess the cleaning did something. I'll clean things up some more and see where this goes. I hope I don't have to de-solder and replace any parts, but we'll see.
All that is wrong is the Convergence IS's. They are located on the deflection board (IC8C01 and IC8C02) and are mounted to a very large heat sink. They are black and are STK IC's, STK392-110. Replace both IC's with STK392-120 and you're in business. The -120's are and upgrade and have a higher amp rating. The IC's can be found anywhere on the internet for $9.99 and up. Check Electronix.com, MCM Electonics, Mat Electeonics for starters. Gook luck. Gary D.
Posted on Feb 08, 2009
Posted on Sep 08, 2008
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
My t.v. dont stay on
First do a hard reset. Merely unplug the power cord for 4 hours, then restart it. This will correct it if the cause is corrupted soft codes.
If not, the protection circuit has captured the power management and you must have it looked at by a service tech.
Let me know if there is more.
Dont forget to rate me as fixya..
Jan 30, 2008 | Mitsubishi WT-42311 42" Rear Projection...
When i press power the timer light flashes and the T.V. turns on and right back off.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Oct 03, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
When I go to turn it on it clicks and then clicks off
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 15, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mitsubishi Model WT42311 Tv . It will not stay on . When you press the power button it tries to come on but turns itself off. Do you have any suggestions?
Yes, do the self check that this set has.
When you try to turn it on and the power light goes off:
On the front of the set press and hold both MENU and DEVICE (OR INPUT) for 5 seconds and release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks---it will repeat the code at least 5 times.
Let me know what code you find and I will tell you what it means and what may have to be done.
2,2 is the most common and the least expensive to fix.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 11, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
and or the
convergence IC's (STK392-110) had failed and caused a diode (D522) to short
out.
If Q5A00 check bad there are other parts that have to be checked or
replaced.
Dec 02, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
369 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
