Infinity KAPPA PERFECT 12.1 Car Subwoofer Logo
Posted on May 02, 2011
I need the dimensions for a infinity 10" 1052 sealed sub box or would a ported box be better?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1661
Points
21
10 x 10 x 4.6 inches ; 11.2 pounds If it were me, I would go with a sealed box. It will hit deeper that way!
- Carbonrue67
I have 3 power acoustik subs and im trying to build a ported box tund to about 30 hz what should b the dimensions of the box???
that requires a formula,go to utube. you need to know what subs you have some require ported boxes and others require sealed boxes.
tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 • Car Audio & Video
tip
Box specs and airpsace for 12 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 13 inches high, x 13 inches wide, x 13 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
2helpful
Hi i have a 15"w3-d4 jl audio sub,can anyone tell me what size antype box i should use ie sealed or ported and the box dimensions
I've had a look at the JLaudio website and they recommend 2 box designs, a ported and a sealed.
The sealed box needs a volume of:
2.125 ft3 or 60.2 litres.
To get this you would need to build the box to these dimensions:
22" x 16" x 14.75" or 559mm x 406mm x 375mm
The ported box needs a volume of:
3.50 ft3 or 99.1 litres.
24" x 19" x 18" or 610mm x 483mm x 457mm.
The port needs to be:
3.0" x 10.9" or 76mm x 277mm.
The enclosure recommendations listed above are external dimensions which assume the use of 3/4" (19mm) thick material. If you are using 5/8" (16mm) thick material, subtract 1/4" (6.5mm) from each dimension. Do not use any material with a thickness of less than 5/8" (16mm) as this may compromise the rigidity of the enclosure.
ā€¢ All enclosure volumes listed above are net internal volumes! Driver displacement, port displacement and brace displacement must be added to obtain the final gross internal volume. All enclosure dimensions above have already taken this into acount.
ā€¢ When using two subwoofers in a common enclosure simply double the required volume and, in the case of a ported enclosure, use two times the recommended port(s). Likewise, when using three subwoofers in a common enclosure simply triple the required volume and, in the case of a ported enclosure, use three times the recommended port(s).
ā€¢ We recommend the use of this speaker in a bi-amplified system using high-quality satellite speakers and a high-quality amplifier. We do not recommend the use of this subwoofer with a passive crossover (coil), as this type of device will adversely affect performance.
As you can see it all depends on the space you have available, whilst the vented box will give you a more efficient bass responce especially with the low range frequencies.
If you to go and look at the information about your sub woofer and find out all the information about building or buying the correct enclosure then this is the link to the pdf file I found:
The enclosure info is on page 3:
JL AUDIO 15W3 Tech Specs and box info.
Warm regards
Mike
1helpful
Is it better to have your sub box ported or sealed
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches. 15 inch, the box will be 16 x 16 x 16
tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
I need to know the demensions for 10 inch subs
almost any 10 will use .75 cubic feet up to 1.25 cu ft. thats about the size of a milk crate give or take. a sealed box will give you the cleanest tightest bass. A ported box will be louder but also larger at the cost of decreased power handling ability and sound quality. If your subs are designed for small enclosures use a sealed box around .75 to 1.00 cu ft.
2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
1helpful
2answers
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
3helpful
2answers
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Sean Wright
Sean Wright
Steve Sweetleaf
Steve Sweetleaf
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
