Question about Hitachi 51S500 51" Rear Projection HDTV-Ready Television
Hitachi 51S500 51 in.
My Hitachi 51S500 51 in. is sick. Everything is fine except the colors. What should be red is green and what sould be green is brown. Blue and yellow are fine. I thought it was the red lamp but when I use the setup tools the red screen shows brightly. What do I do next?
  • Sand Squid Oct 20, 2008
    Thanks for the response. Is this a repair that I can do? If so, where can I purchase the replacement lamp?
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 22 Answers
Check the lamps again you could still have a bad one
Posted on Oct 20, 2008
Colourcode. resistersr512andr514. forPacificsubwooferhcs101circuitboard
Resistor color code is as follows:
Black-0/.0
Brown-1/0
Red-2/00
Orange-3/000
Yellow-4/0000
Green-5/00000
Blue-6/000000
Violet-7/0000000
Grey-8/00000000
White-9/000000000
The first and second color corresponds to the numbers .0-9
The 3rd color corresponds to the zero(s).
So, 512 would be: Green/Brown/Red (5100 ohms)
and 514 would be: Green/Brown/Yellow (510000 Ohms).
Feb 09, 2017 | Computers & Internet
I just replaced six resistors and heat sinks on my Hitachi 43fdx01b
2.2 is red,red and 1.5 brown, green---no polarity.
if you did not change the chips or poor soldering,,,,,,,,
Jun 26, 2012 | Hitachi 43FDX01B TV
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need the stock wire diagram that connects to the car stereo for a 2000 honda civic
2000 HONDA CIVIC FACTORY RADIO WIRE COLORS
BATTERY WHITE/BLUE
ACCESSORY YELLOW/RED
GROUND BLACK
ILLUMINATION RED/BLACK
LEFT FRONT SPEAKER BLUE/GREEN(+) GRAY/BLACK(-)
RIGHT FRONT SPEAKER RED/GREEN(+) BROWN/BLACK(-)
LEFT REAR SPEAKER BLUE/YELLOW(+) GRAY/WHITE(-)
RIGHT REAR SPEAKER RED/YELLOW (+) BROWN/WHITE(-)
Oct 10, 2010 | Car Audio & Video
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Trailer light problem
Check it with a test light. White-ground, Yellow-left turn, Green-right turn, Brown-tailights. Check it on the truck first. There are seperate fuses for just the trailer wiring in the fuse box under the hood. The Blue and Red wires are for Trailer brakes, don't worry about those.
Mar 14, 2009 | 2005 Chevrolet Silverado 1500 2WD
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Hitachi 51S500 51" Rear Projection HDTV-Ready Television Logo
279 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
