Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice Machine I have a KitchenAid refrigerator with a freezer and ice water and ice plus crushed ice dispensor.The modle # 5D119155. The ice dispensor is sudenly not working. I changed the filter and the fauset is on.and water pressure is very good.there is no kink in the verticle plastic t running up the back of the refrigerator. HOW EVER DESPITE THE LEVER MOVING DOWN THERE IS NO WATER IN THE TROUTH, AND NO ICE IS MADE. pLEASE ADVISE ME
Solinoid valve bad
Posted on Feb 27, 2009
  • 943 Answers
Hi thanks for the question i would check the water valve at the back to see if it is ok if you have a volt meter you can check thanks the appliance doc
Posted on Sep 27, 2008
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Ice and water
Remove the top hinge cover on the freezer door and disconnect the plug there . This removes power to the freezer door . Remove the dispensor drip pan and the 2 screws holding the dispensor cover on . Disconnect the plug from the cover . You should now see a circuit board only held on by plastic clips , a disconnect plug on the left side and on the right , 1 or 2 wire terminals . This board is what you need to replace . When getting a replacement , take your complete model number so you get the correct board .
May 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker
you may have a clogged water line going to the ice/water dispensor
Aug 24, 2008 | KitchenAid KSRG22FK Side by Side...
Ice machine works great, but will not dispense
I just repaird a unit with this same symptom. Yours may be the same. The plastic part that holds the switch was broken (pins). See the diagram at http://www.partselect.com/Schematics/Whirlpool/KAZVHYR3.gif Item 15 is the part. The switch sets on a coupld pins and the pins break easily, thus the switch falls off and the dispensor lever can't operate it. If you look up inside with a flashlight you can see the switch, etc. and should be able to tell if it's held in place properly.
Feb 01, 2007 | KitchenAid KSRS25IL Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
