Question about Star Kitchen Appliances - Others
Toaster burnout One half of our four slice toaster has failed as a result of butter patty wrapped in aluminum falling into heating elements and apparently shorting them out. Is this potentially an easy repair fix or is total replacement imminent?
  • 876 Answers
I don;t like to say this, but I think it is a replacement issue. Thank you for using FIXYA!
Posted on Aug 15, 2008
The toaster made a 'pop' sound when I was toasting bagel slice,.., and then it started to smell likie 'electrical burning'. After I unplugged it, cleaned and checked it,... it no longer would operate. The...
Looking for the thermistor is the correct first step. Depending on how the heating elements are wound, mine failed at a bend that wrapped around the panel supporting the element windings. Vaporized a small segment. Unfortunately, i wasn't able to find a replacement heating panel. I suggest you use an ohm meter to check continuity on the heating elements. There will be some resistance. If you find the failed circuit, you're really stuck for repair methods, most elements are not designed to be repaired without the correct welding tools. Good Luck.
Mar 16, 2017 | Sunbeam 3822 2-Slice Toaster
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
Not toasting evenly
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the four in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Mar 26, 2010 | Dualit 31210 3-Slice Toaster
The center panel of my 2 slice Dualit toaster is not heating. Can I replace it?
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Jan 06, 2010 | Dualit Vario 2 Slices Toaster
Inherited a Dualit Vario 3 Toaster without instructions
Good Luck
Nov 12, 2009 | Dualit 31210 3-Slice Toaster
One side not working
Sounds like the element has failed. Not much you can do as even though they cost more than a 2 slice, parts availability is slim and none.
Jan 28, 2009 | Waring WCT810 4-Slice Toaster
T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
56 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
