Phone Number 847-699-9958 New DSL Internet problem getting it installed on my computer. Error message is, Your computer is not connected to the 3 Wire Gateway. e-mail address is russangelico@sbcglobal.net
    Master:
  • 521 Answers
All the doubts can be cleared on this site how to connect , where to connect everything,
http://www.soficom.com.eg/services_DSL_Qa.asp#13
or check this
Some DSL installations require your PC have a network card. If you have to provide this yourself, you are looking for a 10/100mbps auto-sensing PCI network card for a PC. You are looking for something with a brand you are comfortable with, for instance 3com or Intel. Price range is currently from $20-$60. don't waste your money on cards with features such as wake-up packet and lan management, since you are buying for home use.
Several other connection options exist. Residential DSL is often provided with a combined DSL modem and card, that is added to your PC. This card is all you need. These cards are known as PCI DSL modems, and are designed for Intel PCs.
Another connection option is a USB DSL modem. These are newer and more likely to suffer from incompatibilities wth your PC or operating system, but they have the advantage of working on Macintosh, and possibly USB capable laptops as well.
For small business, you are likely to already have network cards, as you would almost certainly have an existing local area network.
Posted on Aug 11, 2008
  • Washing Mach... Master
  • 13,433 Answers
You need to connect your computer to the dsl box and the box to the wall as instructed, you may have to change your internet settings a little.
Find the my network places icon on your desktop, right click and select properties
the network connections screen comes up, you can also go to this via the control panel
right click your internet connection select properties
scroll down the list to internet protocol tcp/ ip select it and press on properties
make sure the settings are set to Obrain an ip address automatically and the 2nd page is empty,
click ok
click ok again
try your internet again.
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Installing a netgear router
    It seems that you need to reconfigure router ,you can use following steps to reconfigure router
    1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
    2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
    3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
    4. On the basic setting page scroll to the bottom and click on Apply.
    5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
    6. Click on lan ip setup under advanced.
    7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
    8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
    9. Power off the dsl modem and the router after making the connections.
    10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
    11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
    12. Access the router (http://192.168.10.1).
    13. Login to the router (Username = admin Password = Password).
    14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
    15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
    16. Click Apply.
    17. Logout of the router.
    18. Open up another browser window and try to access internet.
    May 17, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
    NETGEAR wirless router installation
    You can use below steps to install router
    ROUTER SETUP
    3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.1.1 address bar. press enter
    4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
    5. Click on lan ip setup under advanced.
    6. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
    7. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
    8. Power off the dsl modem and the router after making the connections.
    9. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
    10. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
    11. Access the router (http://192.168.10.1).
    12. Login to the router (Username = admin Password = Password).
    13. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
    14. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
    15. Click Apply.
    16. Logout of the router.
    17. Open up another browser window and try to access internet.
    Please rate the service positively if issue resolved
    Thanks for using Fixya
    Apr 04, 2010 | NetGear RangeMax WPN824 Wireless Router...
    New, second modem won't recognize modem
    You probably need to install network adapter driver on your new hard drive.
    Go to my computer properties, select "Device Manager" and see if there is a network adapter installed and working.
    Dec 27, 2009 | Dell (S423) for Dimension 8100 (3F546)...
    Have SBCglobal with 2wire but want N wireless capability
    Follow the dots -
    2 wire DSL wire to back of DSL modem.
    Ethernet cable out of DSL modem, to current router (if you have one).
    Ethernet cable out of current router (if you have one) to new Wireless N router.
    If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
    Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
    Cannot Connect to the Internet Using a New D-Link DSL-2640B
    1. Make sure you have the latest firmware
    2. Restore to factory settings first. This helped me with stacked ppp session.
    3. Setup your connection according to ISP
    4. If you have problem, install Router Commander from www.routercommander.com
    5. Setup router to send syslog to your PC
    6. Check syslog messages about the clue what's going on
    Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
    No internet connection on my laptops
    Please understand as I get very basic to start but things very obvious to you I cannot see.
    Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
    When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
    If necessary unplug the router and plug the computer back into the original cable until we get the router working.
    Dec 26, 2007 | Linksys Wireless-G WRT54G Router
    Internet connection not working
    I have ATT DSL too.
    Mine came with a Seimens SpeedStream 4100 ethernet ADSL modem. Did yours?
    If not what is the manufacturer and model of the unit ATT sent?
    Is it hooked up and working? If so continue.
    IF you have a Seimens SpeedStream 4100 --
    • It has 3 connection on the back
    • one for power
    • one for a phone line (gray in my case)
    • with a separate gray cable
    • this is connected to the non phone side of a splitter
    • one for an ethernet (yellow in my case)
    • with a separete yellow cable
    • this may be loose to connect to your computer OR
    • connected to another device
    • IF connected to another device what is the manufacturers name and model for that device.
    If ATT supplied a device other than a Seimens SpeedStream 4100
    • Is there anything other than a power adapter and a phone line attached to that unit now?
    • What is the manufacturers name and model for that device.
    In terms of your ATT DSL service
    • How many devices do you intend to connect? Computers, game consoles, etc
    • How many connected by wire, if you know?
    • How many connected by wireless, if you know?
    To you know if your DV4000 computer
    • has an ethernet connector?
    • has a wireless network adapter built-in?
    • IF not can can you look on the label on the bottom of your computer and tell me the full model number is. Please use this Model Link to help figure that out.
    Do you have any devices such as a router, wireless router, wireless access point either already connected or to connect to your ATT DSL service?
    Please identify the manufacturers name and model number for each device and whether or not it is connected and working.
    With all the above I will know where to begin in the process of attaching your new computer to your ATT DSL service. Please add a comment to this issue with the necessary information -- I know it will be long. However you are the hands and eyes of this team and my questions are to get you to tell me things I would know if I was present and installing these devices.
    Dec 16, 2007 | HP Pavilion dv4000 Notebook
    Washing Machines Logo
    24 people viewed this question
    Top Washing Machines Experts
