Question about Microwave Ovens
Microwave fire Microwave came on by itself and started afire within. It got hot enough to burn through the glass plate and ring. Surely this is a hazard owners sould be warned of. If we were not home I don't know what would have happened.
  • gws9 Apr 07, 2009
    does this problem also relate to the ge jvm1630?
  • Microwave Ovens Master
  • 9,086 Answers
Chances are your keypad shorted, or possibly a relay on the control board.
You should let us know the brand and model. There may be a recall.
If you haven't already, you should contact the manufacturer. I bet they would replace it.
Posted on Aug 12, 2008
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Smoke with smoke is coming from the bottom vent of my microwave oven model NN-SE992S of Panasonic make - what are the probable reasons?
1) Food or some like substance has spilled or has gotten inside the machine, and is burning off when the machine is running.
2) You have a short circuit in the wiring of the machine, and it is getting ready to burn up.
Not many places offer microwave repair, and some that do will cost you more that a new one.
Suggest you consider replacing it.
If you are wanting to run it until it:
1) burns off the foreign matter, or
2) run it until it catches afire, please so so outside your house and far away from anything that will catch afire, like perhaps out in your back yard with no grass, or your driveway.
Jul 04, 2016 | Panasonic Microwave Ovens
A small fire started inside the oven. Only the glass broke everything else seems fine. Can I continue using it.
Maybe, maybe not.
You can probably find a replacement glass tray at a Good Will store.
I don't think I'd run it indoors any more. I'd set it on a couple of cinder blocks in the middle of my concrete driveway and hook it to a long, heavy duty extension cord.
Wear a face shield and stand back at least 10 feet after pressing the start button.
You should go to YouTube and search "Can you microwave that".
It's a series of videos.
Feb 26, 2015 | In Microwave Ovens
Glass plate does not go round
Take it out and take any other 'ring part' below it out as well until you only see the small pivot-thingy, then turn the oven on; when you don't see it spinning, motor failed completely and it's probably best just to buy a replacement (second hand or new).
If it does spin, it might be that it's burned out (i.e. not having enough torque anymore to spin the pivot including the glass plate (as the plate adds quite some weight) or jus that some of the plastics fittings are broken. In the later case you might be able to 'fix' it, either by fiddling some wires, glue or whatever. If the motor's just burnt; it's probably best to get a replacement microwave as replacing the engine is probably as expensive as buying a secondhand microwave ...
Oct 17, 2014 | Microwave Ovens
Heating up a heat pack has caused the small
The plate MIGHT cover the waveguide that brings the microwave energy into the cooking cavity, This might be say an inch by two or three inches.
IF the plate has burned or discolored, then it may be carbonized and will continue to absorb the microwave energy and MAY cach fire.
You should service the unit and replace the part.
Running the microwave with too small a load in it can cause this and also if hot food/object touches the plate.
Nov 13, 2009 | Emerson Microwave Ovens
Microwave plate doesn't fit on cog?!
I know this is probably DUMB of me to say, But some with this type of turntable arrangement, The ring would only set one way. The ring did not turn, but rather the wheels faced up and rolled with, and supported the turntable.
Jan 25, 2008 | Danby DMW1145 Stainless Steel Microwave...
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
