We have a philips 44 inch rear projection tv...it is having problems with the color...it is almost as if it is in 3D were the colors look out of alignment. there is also like a rainbow on the bottom of the screen...do you know what is causing this? Thank you!
We actually spent some more time on Google and found a FREE website that told us exactly what it was and also let us download a free manual.
Thanks anyway...I guess.
Posted on Aug 12, 2008
Philips 47 inch rear projection tv turn on but no picture and has a chirping sound in the back
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 06, 2011 | Philips 43P8341 43" Rear Projection...
We have a phillips 57 inch model number 55pw9317f and it has a rainbow and color is awful from what i see with the pictures i am having the same problem but dont know how to fix it . can you help
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2011 | Philips 46PP9302 46" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
My Sharp 61 inch projection HD tv has a blue band of shadow that dips below the image. Looks like 3D without the glasses.
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B misalignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Sharp 61RWP4H 61" Rear Projection...
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
60 inch maganavox rear projection tv blue color almost gone if it is a bulb where can I buy one
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
