Question about Video Game Consoles & Games
When we switch the psp on the power goes straight off even with the adapter on
  • 659 Answers
When the psp is plugged into the adaptor does it look like the unit is charging?
if not then the battery could be dead or there is more issues with the psu on the mainboard of the unit.
if it is charging then the chances are its the screen that needs to be replaced
Posted on Aug 11, 2008
Psp 1001 charging really slow using usb to ac adapter
You have to buy ac adapter I was same I don't have ac adapter but I have powerbank so I can charge it
Feb 22, 2013 | Sony PlayStation Portable (PSP) Console
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
I am trying to upgrade my psp from 5.00 m33 to 5.03 m33 .and I was formatting my psp, my psp just shut down, when i turned it on, the power button turrned green but the screen does not change
regarding with this issue
- try to perform a power drain
- remove the battery
- unplug the ac adapter
- try to hold the power switch for 15 seconds
- reconnect the battery and ac adapter try to turn on the psp
- if this does not work
- try to load the default settings or downgrade the psp back to factory firmware
Hope this help you in resolving the issue
thanks for choosing FixYa
Feb 19, 2011 | Sony PlayStation Portable (PSP) Console
Psp 3001 wont turn on. green light comes on and goes off after 5 secs
try to turn it on using the ac adapter
try to do power cycle by removing the battery and then holding the power switch on the on possition for 15 seconds
if this does not work it might your board needs replacement
Feb 08, 2011 | Sony PSP-3000 Black Console
Nothing comes up on screen even after switching it on
you may have the power-save option on in the psp settings which automatically turns off the light after a certain aount of time to save battery life. just go to settings and find that setting and turn it off if you want that light o stay on
Jun 22, 2010 | Sony Buzz! Master Quiz for PSP
Psp not getting charged..
If you're able to charge your PSP using the USB cable with it connected to your pc, this lets you know the battery in your PSP is still capable of holding a charge.
If your PSP isn't charging using the power adapter there is a possibility that the adapter has malfunctioned and is not supplying the 5v necessary to charge your PSP.
If you're familiar with the operation of volt meter, you can easily check the output voltage of the power adapter by connecting the negative lead of the volt meter to the exposed metal part of the plug that goes into the PSP and connecting the positive to the positive terminal.
The positive terminal will be more difficult to reach becuause it is located in the center of the plug. You'll need a positive probe that has a small enough diameter to fit inside of the hole.
Theoretically you could put a paper clip inside of the hole and then connect the positive lead to it but if you do, you have to take extra care to make sure you don't let the positive and negative leads touch each other.
A better option would be to take your adapter into a store such as Radio Shack and have them test your adapter for you if you're not familiar with the operation of a volt meter.
Sep 13, 2009 | Sony PlayStation Portable (PSP) Console
Psp wont power up .
psp unable to restore games from memory stick
Jul 03, 2009 | Sony PlayStation Portable (PSP) Console
Lisa hunt
faulty power on/off switch connected to motherboard.
replacement repair needed.
Check E-Bay (PSP on/off switch )
Mike @ compurepair.
p.s is the battery in firmly, and power lead A/C Adapter connected ?
Feb 24, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo DS Power problem powers on but goes straight off
You may have not put a connector back on properly....
http://www.instructables.com/id/Replace-the-top-screen-of-a-Nintendo-DS-without-o/
Go there and read it through - there are also other walk-throughs for repairs on this site that are very thorough.
Best of luck
Dec 24, 2007 | Nintendo DS Console
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
