Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Vi forgot my password administrator
I forgot my password administrator
what to do
  • 3 more comments
  • cisneros3080 Nov 12, 2008
    i cannot log on in to my administrator account. i forgot my password, I tried to log on on safe mode and the same problem still persist
  • angelicapur Dec 20, 2008
    i remember what my password is but i typed it in the darcknes so i typed it wrong and i dont know what letters i pressed.
  • lightbulb215 Feb 18, 2009
    I was upset at my boyfriend and changed the administrator password and then the next day i forgot it
  • patrickwhite Mar 31, 2009
    im trying to get into a admin account on a microsoft windows XP hp computer so i can install flash player 10 but i dont know the password and i want to get in the account but when i do the safe mode thing it always asks me if i want to reboot,continue the loading,or do something else sory i fergot but i want to get in there so i can install flash player then log out and go on youtube
  • satash May 11, 2010
  • 4 Answers
Give a try with this Windows password reset utility. It enables you to reset your forgotten admin password.
Posted on Dec 01, 2011
    Scholar:
  • 33 Answers
The average person will try these methods:
Method-1.
Log on your computer by using built-in Administrator account in safe mode, its password default blank if you never change it. So that you can use it to change all other user password.
Press F8 when you start/restart your PC, select Safe Mode to boot system.Or press ctrl+alt+delete two times in the welcome screen.
Method-2.
Use a password reset disk if you have already created.So remember to create a password reset disk when you create/change a password.Insert your reset disk when the system prompt you to use it as soon as you input a wrong password and press OK.
However,how to create password reset disk? For instance creating a password reset disk in Windows 7.Same things can be done in Windows 8,WIndows vista/XP and so on.The operations are similar.
1. Click Start and then choose Control Panel.
2. Click on the User Accounts and Family Safety.
Note: You will not see this link while you're viewing the Control Panel under Large icons or Small icons mode. Then double-click on the User Accounts icon and proceed to Step 4.
3. Click on the User Accounts.
Note: Make sure that there is a portable media being connected on the computer to create the password reset disk before you proceed. This means that you will need a flash drive or a floppy disk drive and a blank floppy disk. You cannot create a Windows 7 password reset disk with a CD/DVD or external hard drive.
4. In the task pane on the left, click Create a password reset disk.
Note: If you get a No Drive warning message at this time, it shows that you have not got a floppy disk or USB flash drive connected onto your PC. You'll need to do this before continuing.
5. When the Forgotten Password Wizard appears, click Next.
6. Choose the portable media drive to create a Windows 7 password reset disk. And then click Next to continue.
7. With the disk or other media still in the drive, enter your current account password in the text box and click Next.
8. Windows 7 now starts to create the password reset disk. Click Next and then click Finish in the next window when the progress indicator shows 100% complete.
9. You can now remove the flash drive or floppy disk from your computer. Label the Windows 7 Password Reset disk and place it in a safe place.
NOTE: You have to renew your password reset disk when you have changed your password. If you forgot to do this, you can't reset your password by the previous reset disk when you lost windows password and it will be much more troublesome.
Method-3.
If the methods above are unavailable,you have to reinstall your system,or else If you really meet this situation, don't worry, you can download a free software--Ophcrack, or reset Windows password with the Command Prompt.
If you want to save time, you can use Windows Password Rescuer professional to deal with this problem. It is designed to recover Windows 8/7/2008/2003/2000/xp/vista password, and it can complete the task within several minutes.
I have used Ophcrack to remove the password, but failed, afterward I used Windows Password Rescuer professional successfully reset my XP admin password, the steps are below(only four steps):
You can free download the program by this link:http://www.daossoft.com/download.html
1. Create a Windows Password Rescuer boot disk.
Download the software and install it in a PC you have access.
Run it and follow the button to burn it to CD or USB.
2. Set computer to boot from CD/DVD-ROM or USB flash drive.
Press F2 or DELETE when you start/restart your PC to get into the BIOS SETUP manu.Use Arrow keys to select BOOT manu,and use +/- keys to move CD/DVD option or USB option to the first site. Press F10 to save and EXIT.
3. Boot from Windows Password Rescuer boot disk.
After setting your computer to boot from CD/DVD rom or USB flash, insert Windows Password Rescuer boot disk you have created, and then restart computer and wait for a moment , Windows Password Rescuer 3.0 will startup and display a friendly operation window.
4. Reset Windows 2000/2003/2008/XP/VISTA/WIN7/WIN8 password with a friendly interface.
When Windows Password Rescuer startup and ready, you can do follow the steps below:
At step 1, All windows on your computer will be list at combo box. Select one you want to reset its password..
At step 2, All Local Group Account will be list at combo box. Select one user you wan to reset its password.
At step 3, Input a password to the password box.
NOTICE: If you system is Windows VISTA or WIN7, Administrator Account may be disabled, and it will not appear at logon screen.
At step 4, Click Reset Password, and eject Windows Password Rescuer boot disk
Posted on Oct 10, 2011
I NEED HELP!! I DONT REMEMBER MY OLD PASSWORD I PUT ON MY OTHER COMPUTOR ADMINISTRATOR AND I CANT LOG IN
Posted on Dec 23, 2008
I cannot log ion ,I forgot my administrator password, please help me
Posted on Nov 12, 2008
  • 57 Answers
How do i factory reset my desktop i forgot password
If you forgot your Bios password then open the pc and reset the COS jumper.
If forgot your Windows password then restart your computer press F8 . select Safe Mode and try administrative login to reset password.
If you forgot the administrator password then use any third party software like Hirenboot to recover it.
May 15, 2014 | eMachines ET183105 PC Desktop
Tip
Lost windows password? you can go into safe mode (F8 when booting up) to reset...
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
on Jan 13, 2010 | Computers & Internet
Forgot password no resset disk
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 04, 2012 | eMachines Computers & Internet
I need help i have forgot the power on password for my hp compaq 6720 and need to know how to by pass it thanks
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
Sep 13, 2011 | HP Compaq 6720s Notebook
How do I reset administrator password
click start
control panel
switch to classic view
click user accounts
then click computer administrator
change password
Feb 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Need to reset the administrative password for my windows xp desktop
Hi there Allenia,
To reset the Administrator user, you need to right click your My Computer and choose "Manage". The Computer Management window will open. Expand the Local Users and Groups from the left panel and click Users. Right click the Administrator user shown on the right and click Set Password. Click OK. That's it!
Please let me know if this helps. Good luck!
Dec 22, 2009 | Microsoft Windows XP Home Edition
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
Nov 28, 2009 | HP Computers & Internet
Can't get pass windows login forgot password for os how do i get in
I know a windows password recovery tool called Windows Password Buster. This software can help you reset the password.
Nov 04, 2009 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
253 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
