Question about Tefal UltraGlide Easycord FV4256 Iron
Hi I have a Tefal Ultraglide 50 which I don't feel produces enough steam to get creases out although you can get a good blast when you press the shot of steam button.I only purchased this around May time to replace another Tefal iron which I had always been really pleased with. I have tried self cleaning the iron but didn't help the problem to any great degree. Any suggestions or, as it is fairly new should I try and get a replacement? Thanks
I had the same problem with my Tefal steam iron, and it turned out the air vent in the fill spout was blocked. I cleaned it out with a nozzle cleaner and it now works fine. to test it try using the iron with the water filler open, if it works OK it's the vent blocked.
Posted on Jan 19, 2012
  • andy_donkin
    andy_donkin Jan 19, 2012
As the iron was still under guarenteeI exchanged it for a newer model
Posted on Aug 12, 2008
Tefal 2932 pro express iron not steaming
Use different water in the iron...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 14, 2010 | Tefal Ultraglide 1549 Iron
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Tefal Steam Generator Model 2911
NO THERMOSTART LIGHT,BUT THE WARNING LIGHT COMES ON
Jan 28, 2008 | Tefal Ultraglide 1549 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Tefal UltraGlide Easycord FV4256 Iron Logo
489 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
