Question about Canon PowerShot A520 Digital Camera
Low battery life
What tips do you have for my rechargeable batteries to hold power longer and not drain out very fast. After rechargign Ultra high capacity Rechargeable AA Powercell Monster Powercell, I am getting ten or so pictures.
Is there anything else possible wrong.?
Do you have a relaible service company in Victoria BC, Canada
  • postcard Aug 19, 2008
    I can (maybe) squeeze out one shot with new batteries. When tested the batteries are still charged but the camera does not activate properly. Sometimes if I take the batteries out and reinsert them I can get the camera to come one for a brief nstant and then it goes dead again.
Exactly the same. Used to be fine before
Posted on Aug 13, 2008
  • 659 Answers
Hey there I find I can use the cheapest batteries and they work fine in my digital camera only if I keep it on. as soon as I turn it off and back on it sucks the battery dry.
the Energizer 2300 seem to be the best of the best in the testing for batteries life.
here is a good read for you on a digital camera batterys
http://www.imaging-resource.com/ACCS/BATTS/BATTS.HTM
Posted on Aug 11, 2008
  • Wesley Gardner
    Wesley Gardner Aug 11, 2008
    also if your flash charges everytime you turn your camera on and you dont use it, that will also consume the battery. only use the flash when you need it.
SOURCE:
Hi have a sanyo x1200 camera havent used it for a few months but fully charged the battery before went to swutch it on but will not switch on???
HERE'S THE ANSWER TO YOUR PROBLEM:
Naturally, for some battery brands and models, recharging happens quiet often since some batteries have shorter capacity to sore current. Some are also designed for a longer time of use. But, here are tips on hoe to prolong the life of your battery:
  • Do not use Super Heavy Duty and other low capacity batteries in high drain devices such as digital cameras.
  • Store batteries in a dry, cool place and avoid heat situations.
  • Fully discharge batteries before charging. This is particularly true for Nickel Cadmium batteries which have a memory effect.
  • Store Lithium batteries (such as the Lithium P7) between 20¡ãC and 25¡ãC (68¡ãF and 77¡ãF) with 30% to 50% charge.
  • Remove the battery if the device is not used for several days or if the device will be plugged into AC continuously.
  • Rechargeable batteries should be fully discharged and charged at least once every 3 months.
Thanks. I hope it helps...
Jul 04, 2011 | Cameras
Batteries go low too fast. New batteries can only last for about 5 camera shots.
You don't say what batteries you are using. I believe this camera takes AA batteries, which come in many capacities. The best batteries for high drain applications are not single use alkaline cells, but high rated NiMH rechargeables. See if a pair of 2700mAh rated ones last longer than what you have been using.
Oct 14, 2010 | DigiLife DDV-C330/C340 Camcorder
Battery won't stay chaRGED NO AMPS SHOWING ON AMMETER.CAN BE STARTED BY JUMP AND WILL RUN BUT STOP AND WILL NOT START AGAIN WHATS MY PROBLEM?
it could be a fuw things doing this,,,
check that the engine is charging the battery up when its running,,use a volt meeter across the battery it should show 13.5 volts if its charging up ok,,,,
then check that the voltage regulator is not draining the battery when the engine is not running,,,
fully recharge the battery first then check that it holds this charge,, take off the battery lead and leave the mower for a week or so if the battery has gone flat then you need a new battery!! winter time kills off batterys if there not kept on trickel charge,,,
there's a tip,,,,buy a solar charger,,,and hook it to the battery when your not using the mower,,it will keep the battery toped up for free???
Jun 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Hi I have an Olympus SP-560UZ that eats batteries almost as fast as i can charge them. My batteries are Rechargeable NiMH 2700 and almost new. I am only able to take six to ten shots before the battery...
Hey donoman,
I am going on the assumption that these batteries are not new. Most rechargeable batteries lose their ability to hold a charge after time, and it might be time to invest in new batteries. Another cause of this could be that you are mixing older batteries with newer batteries, and by doing this the length of the charge is dependent on the weakest battery. Things that significantly affect battery life are camera flash, LCD screens, and battery temperature (the lower the temperature the quicker the battery will drain). Another thing to consider is when a rechargeable battery starts to fail they fail quickly, where disposable batteries generally have a longer life and drain at a more constant rate.
Sincerely,
Allan
Go Ahead. Use Us.
May 08, 2008 | Cameras
Will not turn off?
Can I guess that you are using regular batteries! I discovered a long time ago that regular batteries will not last long, and maybe not have enough power to even get the camera started! Get Ultra-High Capacity Rechargeable batteries and a charger. The charger usually holds 4 batteries and you will only be using 2 at a time. They are expensive to buy but they are rechargeable and will make the camera work. The going in and out is the sudden drain on the batteries that is needed to open the lens and that causes the fast voltage drop which shuts the camera off. This will cycle over and over. Very anoying!
Mar 10, 2008 | Vivitar ViviCam 5386 Digital Camera
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Battery Drain
1) Rechargable batteries have a finite life. At some point they'll no longer hold their charge. This may be the case with your camera. 2) Alkaline AA batteries do not perform well with digital cameras or other high drain devices. They can not maintain a voltage level these devices require. It is unlikely you'll get much use out of alkaline AA's with your camera. The solution? Buy a new rechargable battery for the camera.
Sep 13, 2005 | Kodak EasyShare DX4900 Zoom Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Canon PowerShot A520 Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
