Reset bios on Toshiba A215
According the one of your posts on FixYa you reset bios to clear the password. How did you do this? I got a password to enter the bios that I can't remember.
  • inuyasha5891 Mar 13, 2009
    My Toshiba A215-5818 usually crashed, with the power light and other led lights still on, but the screen would be blank. I did some research on the issue and found that Toshiba instructs that users should download and upgrade their BIOS. I tried doing that, following every detailed instruction. I got to the middle of flashing the BIOS when it suddenly crashed! When I try to reboot, the power light is on and the FN key works for a couple of seconds and freezes, but I get no BIOS messages, such as Press F2 or Delete to enter Setup etc. Just a blank screen. Is there a way to refresh the BIOS by shorting it? If so how would I do this effectively? Or is the entire Computer MoBo bricked?
This should be able to be solved by opening the Ram bay and shorting out two solder points. Usually marked with a "xxx". The notebook should be started with these solder points shorted. Once the pc is on, it should go through the normal process without asking for a bios password. Once the pc is restarted, the CMOS password should disappear.
Cheers.
DOC
Posted on Jan 16, 2009
    President:
  • 2,961 Answers
The only way to do this is to remove the cmos battery for 5 mins or so or short the jumpers on motherboard, battery way is easier
Posted on Aug 13, 2008
Hello, I´ve tried it several times with the shorting method and nothing happened, but then i changed the hard drive for another one and everything changed, the F2 and F12 options came back. Then i´ve put on the original drive and these options still remains active. Sorry for my english. bye
Posted on Jul 22, 2010
How to remove CMOS battery for A215-S7444? I done a search and got this answer: "This should help: * Remove Laptop Battery * Remove Memory Cover * Spread spring clips to outside and * pull out RAM...
What are you trying to do? Replace the CMOS battery, or reset a BIOS password?
This is what the CMOS battery looks like,
http://www.ebay.com/itm/CMOS-RTC-Battery-Toshiba-Satellite-A210-A215-Series-/270970735656?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D160437620636%26ps%3D63%26clkid%3D8748715535548215160
Now view this pictorial disassembly guide,
Page 1 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Page 3 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
Go to the photo in Step 17, and click on it to enlarge.
See the CMOS battery in the middle/left?
Round silvery looking object. Go straight down from the red arrow to the far left.
That is how to access the CMOS battery.
(Yes I know it states Satellite A200/A205. Same for the A215)
Now BIOS password reset?
Do not know where the two copper pads are to briefly short out. Suspect under the Ram Memory modules, (And under a small sheet of Mylar plastic), or under the Wireless Modem. (And under a small sheet of Mylar plastic)
The links on this solution I gave may help,
http://www.fixya.com/support/t6645137-toshiba_l500_clear_cmos
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Am I concerned that you may have stolen the laptop, or are trying to break into someone else's laptop?
NO
Your real name, and IP address are recorded on FixYa, to give to the authorities, if needed.
I figure a thief would not risk this ]
May 28, 2012 | Toshiba Satellite A215-S7444 Notebook
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
Apr 20, 2010 | Computers & Internet
Toshiba a215-s4807 builin hdd1 password please
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 22, 2009 | Toshiba Satellite A215-S4807 Notebook
I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Nov 04, 2009 | Toshiba Satellite A215-S7437 Notebook
Toshiba satellite a215-s7437 bios pw
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
Jun 21, 2009 | Toshiba Satellite A215-S4747 Notebook
Need to reset phoenix bios on toshiba A215-s5825. Bios password has been set by accident. Backdoor passwords do not work, and removing battery from the motherboard did not work. Please...
If there's a shorting terminal in your mobo for reset BIOS PW short it with its shorting pins then check it out again if PW is cleared from BIOS.
May 24, 2009 | Computers & Internet
I have an Toshiba A215 and cant remember the admin password how can I unlock the system to change my password. I have a toshiba satellite a215-7417 and need to reset bios. I heard something about shorting...
Do not attempt to short out the jumpers on your own. As simple as it is, you can also kill the board. Also, the RTC battery will not effect the BIOS password. Take it in to the nearest Toshiba ASP center and they will reset the BIOS password as well as update it to the latest BIOS revision to avoid it from happening again UNDER WARRANTY. You do not have to pay for this repair.
Mar 16, 2009 | Toshiba Satellite A215-S5822 Laptop
Satellite A215-S7422 Lost BIOS Password S#y7066387q need to no location of CMOS reset no time for louisville
Hi there, and welcome to FixYa.
Two ways to solve your BIOS problem:
One:
Removing the battery inside for the bios and find the jumper for clearing the CMOS.
Two:
Download your flash BIOS from here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
As you don’t have a diskette on your model, you might be able to install it on a memory key, and boot from that, depending on your previous BIOS setup???
/Teis
Do vote before you leave,
Thank you
Nov 28, 2008 | Toshiba Satellite A215-S7422 Notebook
BIOS PASSWORD
There is a trick to resetting the BIOS password , but it requires you to open the laptop and get to the motherboard. Now I don't know your level of expertise in that field , but laptops can be very trick to pull apart and put back together...so if you are not comfortable doing it , please take it to a professional as I don't want to see you damage your laptop!
Back to resetting the password......you need to access the motherboard of the laptop....on the motherboard is a small circular battery (it is flat and silver)..... that needs to be disconnected from the motherboard to reset all the BIOS information...depending on the model of the laptop , you may be able to completely remove the battery from the clip it is in , or you may need to disconnect the wire running from the batter to motherboard. Below I have put some example pictures to make it clear.
Removing That Battery:
Disconnecting The Cable:
After disconnecting it/removing it place it back in/reconnect it , put the laptop back together and boot up....the password will be reset! Below is a picture just in case you have trouble finding the battery
If this post helped you please leave a rating, it is well appreciated, thanks!
Oct 02, 2008 | Toshiba Satellite A215-S7422 Notebook
Satellite A215-S7416 Bios Password
There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
http://www.ccl-la.com/blog/index.php/clearing-bios-power-on-passwords-on-toshiba-laptops/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 17, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
3,074 people viewed this question
David Payne
David Payne
