Question about Kenmore 24432 Top Load Washer
Tube will not drain
The lid switch is ok, hoses are not plugged, I can drain the machine by lowering the drain pipe to a low pan or bucket, so out filter is not plugged with lint. Is it possible that the pump would ned to be replaced?
Sorry, no solution. I discovered that the gearcase had gotten jammed. The machine is 8 years old, so it is not worth the cost of replacing the gearcase. Thanks for trying. P.S. The correct model # is 110.29842990, not 24432.
Posted on Aug 13, 2008
I have a top laoder whirlpool8564990 it don´t spin well it leaves my clothes soaked and it goes to spinning cycle yet it don´t spin
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Washing Machines
Amana front load washer has wet clothes after the complete wash cycle finishes
Oct 13, 2016 | Amana Washing Machines
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
Oct 13, 2016 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Drum fillingup an over flowing
Check the flexi drain pipe for any clogging. Pour water into the pipe by keepin at your arm level. Once it is full close the pipe mouth with your hand and lower it to a bucket or drain. Check for any deberies,
Try the machine drain. Still not draining, drain valve is stuck.
Call the L G technician to set it right. Sometimes the fault could be in the micr controller also.
Jul 02, 2015 | LG Washing Machines
How do i drain the washer for moving it
Mike,
I cannot tell whether you are talking about (1) the little bit of residual water in the machine after it's done, or (2) about a machine that's stopped mid-cycle with a good deal of water, so I'll respond to both cases.
(1) The lowest point in the washing machine is the drain outlet at the back to which the drain hose attaches. First remove the free end of the drain hose from the drain pipe and place it in a bucket sitting on the floor. That will get most of the water. Then place a towel on the floor and remove the other end of the drain hose from the machine. Remaining water will spill out from the outlet and hose onto the towel. You might get a little more if you lift the front of the machine, tilting it backward.
(2) If you can't drain the machine and it's full of water, you will need to siphon it. Take a piece of tubing, at least five feet long. You could use a piece of garden hose if you have nothing else. If you don't have a door or window nearby, you will need TWO buckets. Place the buckets on the floor in front of the machine. Place the siphon hose into the washer tub starting with one end to fill it with water. When it's completely in, cover one end, take it out, place it into a bucket. If the siphon doesn't automatically start, get down low on the floor, place the hose into your mouth and inhale. You may have to do this several times, possibly covering the tubing end with your tongue between inhalations. When the bucket is nearly full, switch the hose to the empty bucket and empty the first one. You will probably have several buckets of water. (Of course if your washing machine is near an outside door, you can simply start the siphon outside and omit the buckets.)
Oct 02, 2014 | Washing Machines
"OE" message
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
May 02, 2010 | LG WM-2277HW Front Load Washer
Have the Indesit Moon washing machine and it will not finnish the wash cycle and go into spin mode. Is there anything I can do? Thanks
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Apr 14, 2010 | Indesit W 123 Front Load Washer
I have a split system SAP-K181AHA, SAP-K241AHA that is leaking water from unit inside house.
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Jan 07, 2010 | Sanyo Heating & Cooling
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Washer is not draining the water out automatically.
check for a faulty door/lid switch. can oyo uhearit click when the lid is closed??? your probalby causing a syphin action when lowering the drain hose in to the bucket. so i probably wouldnt pay mind to that
Mar 17, 2009 | Kenmore Washing Machines
Kenmore 24432 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
