Question about Konica Minolta DiALTA CF910 Copier
CF910- How do I get rid of a P2 NG
Why do I get streaks when I run a graduation adjustment. Why can't I clear a P2 NG in the utilities fram.
  • ftonna Aug 28, 2008
    My copies are coming out with a black background. The service Tech played around with the CMYK configuration on the machine and he can't get it back to print out clean copies. Also when he runs a gradation page the same happens
    Master:
  • 521 Answers
Its not a major problem.its only because of the waste ink collected in your printer have now started spreading in the printer printing area.this type of problems occurs many times in all the printers.you just have to get it serviced.i dont know why the service technician you called have not done this.i think he was not having proper knowledge of your printer.just get it serviced from a proper service center.your printer is perfectly allright.100% ok.and also come in use to you for long time.just maintain it properly by regular servicing.when ever you receive such problems.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 28, 2008
  • 6,487 Answers
For this type of error message Factory service required on teh device...So better take it to a service center..
Hope that helps.......
    Genius:
  • 1,269 Answers
Turn off the device and unplug the power for 5 mins. That should clear it.
Tataas kaya ang mga grades ko sa school?
oo naman. Basta mag aral ka maigi, then have google as your ally. laging masigasig ka sa research, kahit out of this world ang topic ng prof mo Ok lang yan. Then pag graduate ka na, mag-isip ka ng magandang negosyo at cyempre login ka rito sa Fixya.com para matutunan mo paano isosolve ng tama ang mga problema ng buong mundo ukol sa bagay bagay. Hope it helps!!
Feb 14, 2011 | Computers & Internet
Scanner produces streaks
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Jun 29, 2010 | Canon DR-2050C Path-Through Scanner
Just purchased the new Mac OS X 10.6.2 and it doesn't read our 2 Konica Minolta CF910 printers. Any suggestions?
Sir CF910 is a legacy equipment, try going to konicaminolta US web site look up you machine and down load the driver for it if a available once again CF910 is a first gen color machine from minolta,
Apr 23, 2010 | Konica Minolta DiALTA CF910 Copier
Having problems telnet a port
Try opening a TELNET connection to TCP port 25 on each of these mail-servers for the 'ncs.gov.ng' domain:
ncs.gov.ng mail exchanger = mx2.ncs.gov.ng
ncs.gov.ng mail exchanger = ASpmx.l.google.com
ncs.gov.ng mail exchanger = mx1.ncs.gov.ng
Each *SHOULD* connect; if not, contact the administrators of 'ncs.gov.ng' for assistance.
Oct 29, 2009 | Microsoft Windows Vista Home Basic for PC
I have a 37 with a black streak developing on screen.
It can be problem of LCD panel of your TV. An image of TV screen would help to diagnose correctly, if you can post it here.
Thanks.
Sep 14, 2009 | Protron PLTV-37 37 in. LCD Television
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
How do I get into service mode on a Konica Minolta Bizhub C250 copier and how do I adjust the color settings once I am in there?
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
May 13, 2009 | Konica Minolta Office Equipment & Supplies
Problem printing photos
When printing a photo make sure that your quality is set on best and not normal.
Also check the ink level on your colour and black cartridges and make sure it is sufficient.
Last but not least if you are using remanufactured or refilled cartridges this is a common problem. The cartridges are not made for the printer or they have been refilled and they now have blocked printheads and the ink is doing interesting things. If you buy a real hp cartridge and it should clear the issue up.
Dec 16, 2007 | HP Deskjet F340 All-In-One Printer
Lines on top and bottom on projection TV
What sort of lines? - do you mean like it is in widescreen mode with a black band top and bottom? Do you mean you have clear straight lines, or streaks or scratch-like marks? Is it the same for all input sources (cable, DVD/VCR, satellite, PC, camcorder etc.? Could you post back a photo of the lines? Waiting your info:)
Jul 16, 2007 | Sony KP-43HT20 43" Rear Projection...
Konica Minolta DiALTA CF910 Copier Logo
88 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
