Question about Kenmore 63942 Dryer
Replacing the heating element
I am trying to find the heating element on my Series 90 Kenmore Dryer.  I would like to find the manual as well, as I am more visual.  Thanks in advance.
Reggiesmith770@yahoo.com
  • 481 Answers
  • take the back off and it is in the metal case on the right. here is some visuals.
  • the second picture shows the element pulled out of the canister.
  • some of the newer dryers don't require you to remove the canister; there will be 4 screws on the back of the canister to remove the element shown as red dots in the 3rd picture.
  • if these pictures don't match what your dryer looks like then give me the model number of your dryer.
Replacing the heating element - 7a8ed6d.jpg"http://i.fixya.net/uploads/images/7a8ed6d.jpg" alt="7a8ed6d.jpg" class="h_mi" />
Posted on Aug 11, 2008
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Need to replace element in kenmore series 90 dryer part 3387747 model 11068972890 need access to manual or video on how to open op dryer and replace part or determine problem since dryer will not heat...
check out this video it will show you how to take it apart,to test those parts first before replacing them use a ohm meter and check the element for appx. 10-20 ohms and BOTH of those thermostats on the outside of the heater housing for ZERO ohms
Aug 10, 2011 | Dryers
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
the part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
No heat for dryer
Need to look at replacing the thermostats and heating element whaich are accessible behind the dryer in a small panel. Be very careful to watch for sharp edges and disconnect the power before you do ANYTHING else. It's a relatively easy fix and you can get the parts feom www.marcone.com
Mar 14, 2008 | Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
110 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
