Question about Akai CTS2550 25" TV
Del lcd monitor E172FPb Stoped working after linghting storm. Replaced blowen main fuse. ZAP! Fuse blew. Slight buned smell.
  • 555 Answers
I believe you got transistors with short circuit. Here is a website indication about this issue:
http://josepino.com/?howto-repair-dell
Good luck.
Posted on Sep 04, 2009
2010 highlander ac not blowing
Blower is bad. That's the only thing that could blow a big fuse like that. Besides a shorted wire. You would have smelled burning rubber with this.
Mar 20, 2016 | 2010 Toyota Highlander Limited
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
I accidently put my battery in my car wrong way have changed it back after starting my car now the central lock/heater/inside light eletric windows dont work until i start the car
u blew ur fuse look the fuses under dash replace the ones u blew n u more likely blew 1/2/3-4 under dash to check them u sent back current thru live wires n grounded wires that arent suposse to have juice going thru to etc. u may even zap ur altnator the few times ive crisscrossed them i fried altnator or fuse but thats what fuses are meant for to much of one or another current to it zaps cuts off electricity going to so it dont zap it protects the main area from being fried so easily
Aug 31, 2010 | Mitsubishi Lancer Cars & Trucks
The power light on our model E172FPb Dell monitor is blinking. The screen does not turn on. What could be the problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Boards: www.lcdrepair.us
May 19, 2010 | Computers & Internet
I was out riding yesterday when all of a sudden my bike died all the electrics went! its a 1995 cbr 600f main fuse blew and the voltage regulator was boiling and the rubber encasing the circuits had peeled...
the regulator only keeps the voltage regulated to about 13v charge for the battery no matter what speed you ride..if the regulator did not work correctly you might start to burn out light bulbs. So when you put in the new regulator make sure your battery is at least at 12.3v minimum if not you will have to push start it and ride it for about 15 minutes on an open highway to charge the battery back up to at least 12.6v-12.7v...13v is perfect. (if none of your other fuses blew then all other electrics should work), so i would double check all of your fuses just to make sure.
Apr 26, 2010 | 1995 Honda CBR 600 F(3)S
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
How do you restart a nec lcd monitor, had power surge everything but monitor gets power?
The power surge probably blew the fuse inside the tv, first check the fuse inside the mains plug, if that is good then you will have to take the back cover off the tv, you are looking for the power board follow the mains cable into the tv and you will find it. Look for a fuse on the board, pop it out of the fuse holder, if you have or can get hold of a multimetre check the fuse for continuity if it hasnt you will have get hold off another fuse, you can normally get them from your local electrical repair shop, they dont cost much and the liklyhood is they will probably give you one free of charge.
Feb 04, 2010 | NEC MultiSync 1760NX 17" LCD Monitor
2wh7rca r54 - blowen fuse after replaced
You replaced the fl23 fuse? Did you rember to resolder the connections on the flyback?. Look in the tips and tricks section for the fl231 fuse problem
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
T.v. keeps blowing a fuse
The storm probaly blew your horizontal output or one of the Diodes in the brdge rectifier. Hows your soldering skills and what model set do you have?
Jan 21, 2008 | Televison & Video
Turntable, lights and fan inop
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Akai CTS2550 25" TV Logo
62 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
