I have a samsung big wash q1435v 7.5 kg that is not working it is displaying error code 8e?
  • Anonymous Nov 12, 2008
    Pra?ka Samsung Q1435V Big Wash hlásí problém 8E.
Maanita
  • 1142 Answers
SOURCE: Spin cycle wont work and
It doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Aug 05, 2008
    rdrsp
    • 85 Answers
    SOURCE: my samsung washing machine model WA13513 13.5kg
    OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    IPM: Integrated power module. The IPM controls the motor.
    If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
    If the motor stops working, in one direction ten times, “8E” Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
    would advise calling a tech... hope this helps.
    Posted on Oct 25, 2009
    DirtyOldGit
    • 5 Answers
    SOURCE: what is the AE error code on LG steam direct drive washing machin
    the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
    PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
    Posted on Mar 31, 2010
    • 6277 Answers
    SOURCE: my washing maching,hotpoint aquarius 7
    There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Either require a service engineer's attention I suggest ;-0(
    If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
    Thanks and good luck!
    John C
    Posted on May 05, 2011
    SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
    hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
    Posted on May 22, 2011
    Error E1 for washing machine
    Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does error message F-10 mean
    Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
    Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
    Samsung front loader 8 kg will not spin.
    could be motor brushes or capacator
    Apr 23, 2015 | Samsung Washing Machines
    Fault error code 8E
    an 8E or 8E2 means - Sensor problem.
    Feb 19, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
    Samsung refrigerator error code 8E
    8E = OVER CURRENT ERROR
    If the motor stops working, in one direction ten times, "8E" Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
    Nov 23, 2012 | Samsung RS265TDRS Side by Side...
    Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
    5E. Water Drain Error.
    5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
    can be rectified by turning the POWER SW OFF AND THEN BACK on.
    Hope this helps you
    Feb 01, 2012 | Samsung Washing Machines
    E8 front loader washing machines
    OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    HOWEVER, the UK White goods website says:
    E8
    Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
    You can find more about your Samsung Washing Machine error codes at:
    http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
    or
    http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
    Jun 21, 2011 | Samsung Washing Machines
    My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
    Oct 25, 2009 | Washing Machines
    E8 error code
    8E - OVER CURRENT ERROR
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 02, 2009 | Washing Machines
    Washing Machines Logo
    207 people viewed this question
    Top Washing Machines Experts
