Rca 32 inch
I had my tv repaired and it had a bad I C and also repaired the printed circuit board , but now all of a sudden the picture went to bright orange and blue colors and blurry, so what could it be.
  • 1,550 Answers
Maybe the eeprom are corrupted
Posted on Aug 11, 2008
Rca 32" lcd tv.vertical lines on entire screen,no pix.
? 5:29 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
TV went "pop"
prob not worth repair sounds like horiz sweep circuit. 150 200 to repair.
Nov 30, 2008 | Zenith A32B41W 32" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Mar 14, 2008 | RCA 32V524T TV
Dead tv
That is typical with these units, The Horizontal output transistor and flyback go out in the RCA's 9 10ths of the time and causes this situation.
Sep 15, 2007 | RCA F32669 32" TV
32 inch rca color
If this is a 32 inch TV then it is a standard picture tube set. If the colors have suddenly gone out of whack, and the set has not been dropped or had any large magnets near it recently, it means that the degaussing thermistor has come loose from its legs. This is very common in the RCA regular picture tube sets. If you look in the back of the set you will see a large black coil of wire wrapped around the edges of the picture tube, with 2 white wires going down to a jack on the main PC board. Right next to that jack is the degaussing thermistor, which looks like a small silver disc, like a nickle, with 2 legs loosely soldered to its sides. One or both of those legs are probably loose, and if you are very careful you can solder those legs back onto the thermistor. If you do not have experience soldering small parts, allow a qualified tech to handle it for you.
Aug 26, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
32 inch panasonic tv
Your problem is in the vertical deflection circuit. If you know how to solder it may just be a cold solder connection, but if you try to solder it and it still does not work, you may have a bad Vertical output IC. This set has really no user replaceable parts unless you have some no how on serviceing solid state printed circuit boards. If you dont , my advise would to seek out a repair depot and have them fix this set for you. It should not run more then 150 bucks or so. Good Luck Ps please do not forget to rate this thread.
Nov 12, 2006 | Panasonic CT-32D12D 32" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
