Question about Panasonic PT-47WX49 47" Rear Projection Television
Tv shutting off
Hi our projection tv is just shutting off.. We actually have to unplug it and plug it back in to make it work again until it does it again any ideas? and costs on how much to fix range? Same problem as above, removed rear cover and can phisically see a diode or resistor on ckt bd. #TNPH0341 at position R517 completely burned. Prior to this we could hear what appereared to be a high voltage short or snap that would momentarily blacken the sreeen. This happened on a high humidity day.
  • 1,031 Answers
If the horizontal safety cct trips you have to unplug the TV
to reset the shutdown status
since it was plugged with no surge protectors
I replace what ever cord first and check the power outlet for the correct supply
the burnt component might be proctecting the
convergence IC which will effect it and equally
the voltage supply could causing the switching off
unplug the TV check the CPU PCB if damaged needs repair or replacement
Posted on Aug 11, 2008
  • 4,234 Answers
If this part measures open, replace it usniog the Panasonic part number: ERSD2TJ103. Thi part is available for $1.09 from tritronicsinc.com
hope this helps,
Dan
    Master:
  • 521 Answers
Yes get it replaced and you can remove the old one and fit new one through soldering iron thats very simple it will very very less dollars you have to spend on this . do it slowly and carefully.
  • 2,326 Answers
The high voltage snap appears to be from one of the CRTs leaking coolant liquid and it could probably got to the circuit board, this liquid is highly corrosive and will cause conductivity if it came in contact with the components.
The repair could cost you about 1/3 of the price of the TV in some cases or a bit more.
Picture is to big for screen after DVD watched
Teri, you will have to change the TV's picture settings until everything fits screen again, actually try unplugging for ten minutes and plug back in, this may reset it.
Feb 23, 2016 | Televison & Video
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Tv shutting off
when it shuts off, press the power button and see if the power led blinks and if it does let me know the number fo blinks. Please respond to this same post when replying.
Aug 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
TV turns on and then suddenly the screen will shut off but the power will remain on
there is a problem somewhere in the power supply or horizontal circut.
It will need a technition to troubleshoot this problem.
Thanks Guy9
May 04, 2008 | Hitachi 50UX58B 50" Rear Projection...
TV pops then shuts off.
FUNNY.... cause I just started having this problem also... I have had this TV since they first came out. LOVED it.. now I HATE it. I can watch for about an hour then POP the TV shorts.
wait a couple of minutes and you can get maybe another hour until POP again!
Mar 11, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Repair issues
call the repair shop back to let them know that there is a possible fault and have it notated they must offer some kind of warranty on their repairs/
Sep 10, 2006 | RCA HD52W59 HDTV Projection Television
Panasonic PT-47WX49 47" Rear Projection Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
