Question about Canon Office Equipment & Supplies
My printer is an mp610 series. When I try to print a 3,5 x 5,5 tract with the type set at Arial 11 pt, the print is athe smallest possible, and doesn't print out in tract format.
I just kept on changing items in My Printer program and on my Print program, reversing at times what made sense to me, and finally the result was what I wanted. Thanks!
Posted on Aug 12, 2008
My black and white photos will only print out in sepia. I have plenty of ink in the Cartridges of my MP610. Please help?
Two possibilities come to mind:
  1. There is a function in many printers that lets you print in the single colour of your choice. Check every tab and every "advanced..." dialog box you get when you are about to print. Then go to the printer's properties in the control panel and check whether there's anything like that
  2. Many printers let you print black with black ink, OR alternatively make black by mixing the other three colours CMY. Look for that setting in the same places and deactivate it
Feb 27, 2013 | Canon MP610 Photo All-In-One Printer
My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Mar 09, 2010 | Office Equipment & Supplies
Cannot scan to mp610, but can print (both using bluetooth)
Regrettably, scanning over bluetooth is not possible. Both theoretically and practically. Scanning requires huge amount of data packets to transmitted that is not possible over bluetooth.
Sep 04, 2009 | Canon MP610 Photo All-In-One Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Inner cover of printer MP610 -error 'inner cover not closed'
I am still on . Get back if your problem is not solved.
Aug 03, 2009 | Canon PIXMA MP610 InkJet Printer
MP610 with poor photo printing, colors off, low quality
Adjust the driver settings and you will have success.
Jul 08, 2009 | Canon MP610 Photo All-In-One Printer
Colors not printing
hmmm..interesting..you get new drivers on that printer? try here, just in case it's an older set for your operating system.
Mar 16, 2008 | Canon MP610 Photo All-In-One Printer
Can't install mp610 printer
The drivers for the printers you deleted may not have been deleted from the system print server.
Play it safe and make sure you have source files for re-installing any print drivers you delete.
From the "Printers and Faxes" window, select File/Print Server.
Select the DRIVERS tab, delete any drivers referring to the Canon printer.
Reboot or alternatively, use the services.msc to stop and restart the print spooler service. Now try to install your new drivers.
Nov 20, 2007 | BenQ MP610 Multimedia Projector
20 people viewed this question
old marine
old marine
