Question about Toshiba Satellite A135-S4527 Notebook
Internal network adapter
Hi
i have connection to my home network except there is limited connectivity
our modem is in the garage so i think that's why i can't access it
is there any way i can enable an internal network adapter to access the internet?
    Problem Solver:
  • 5 Answers
Wait have been thinking not to close the doors thats why it wont reach you laptop
Posted on Aug 11, 2008
How to connect laptop (using internal wireless adapter) to a wireless network)
Make sure you have the correct Password exactly like it should be (case sensitive). If it is not correct, it will continue in the loop of trying to validate identity.
Also you can click Start/Control Panel/Network Connections then Right Click on the Wireless Connection and select Properties.
When the properties window opens click View Available Wireless Networks. Highlight your network by clicking on it then select Properties.
The Association tab will allow you to change the Network Authentication to WPA2-PSK if it is not set to that and if the adapter will accommodate it. And you can put in the Network Key or Password.
May 05, 2012 | HP Compaq Presario V2000 Notebook
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
LImited or no connectivity on wireless router after reset
hi
go to the router wireless settings and check to see if the wireless connectivity has been disabled as a part of default settings
cheers
Pls rate if this was any help
Jul 04, 2009 | Microsoft Wireless Network Adapter Xbox...
Dear forum-freinds, I have Motorola cable modem type SB5101E. From a month ago up to now I can't use my cable Internet because it's been dropping connection after 5-9 minutes after restart. Nothing happens...
If you say the lights are going out on the modem when it boots you off the network then the problem is your modem and not your internet connection, if the modem is new take it back and have them swap it for another one.
Regards.
Jul 01, 2009 | Arris SURFboard SB5101 Cable Modem
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Toshiba Satellite A135-S4527 Notebook Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
