Question about SanDisk Sansa e250 MP3 Player
My sandisk mp3
When ever my sandisk is connected to my computor it work but when its not its stops working and it won't turn on
Take out the backing and then the batt hold the power/menu button for 30 sec.put batt back in.
Posted on Aug 26, 2008
You may have the mp3 player locked. Check the top to see if orange is showing, if you the player in on hold and that is the cause of it not starting up.
Posted on Aug 11, 2008
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
My SanDisk 1gb stopped working
I HAVE THE SAME PROBLEM. I CALLED SANDISK. THEY ONLY MADE ME MAD. THEY TOLD ME I CAN SEND THEM THE HARD DRIVE, BUT I WILL NOT GET MY INFO BACK. THEY WILL SEND ME ANOTHER DRIVE. SO I WENT OFF, BECAUSE I HAVE ALOT OF IMPORTANT INFO ON MY DRIVE. SO THEY GAVE ME THIS NUMBER 866-603-2195 TO LC TECH THEY RETRIEVE DATA FROM THE DRIVES. THE FEE IS 75.00. YOU DO NOT SEND THE MONEY WITH THE DRIVE. WHEN THEY HAVE RETRIEVED YOUR INFO THAT'S WHEN YOU PAY.
GOOD LUCK.........
Jan 26, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sansa is not working
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Dec 21, 2008 | SanDisk Sansa m240 MP3 Player
Won't turn off
hold the on button up untill it turns off that always works for mine
Nov 08, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
SANSA EXPRESS
Not sure but it could be dead, but dont worry till you do a hard reset by pressing and holding down the "select(Square button)"and "volume up" buttons.
I just got mine today and been looking through the sandisk forum.
Hope that helps bye :)
Jun 15, 2008 | SanDisk Sansa MP3 Player
Sansa Wont Connect to the Computer
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 10, 2008 | SanDisk Sansa e260 MP3 Player
No driver
u may need to update something on either ur computor or mp3
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
My sandisk mp3 512 player won´t start
i really dnt kno this happened to me too im tryin to fix it the best thing u can do is call em up on sandisk.com IF u havnt already tried to mess wit it already if u do find out how to fiix it, PLEASE email me at tsingh66@sbcglobal.net
Mar 19, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
