Question about Jabra BT150 Wireless Headset
Can't turn on ! no in structions w/ear peace. LG PHONE(chocolate) can't find ! BT150 Jabra ! I do'nt know wich buttons are what? how long it last, or when its charged ? H..E..L..P....!!!!
  • 2 more comments
  • Anonymous Dec 11, 2008
    can not trun it bt150 on
  • Janet Ragusa
    Janet Ragusa Jan 20, 2009
    I HAVE NO INSTRUCTIONS
  • gmwensma Mar 02, 2009
    I have tried everything too. When I put the charger on for the first time after purchasing and plugged it in there was just a quick blue flash but no lights came on ever.  Help...
  • Anonymous Mar 11, 2009
    i have the exact same problem. i plug it in and get a small blue flash and thats it!!   Cant get it to turn on!!! ARRRRRRGHGHHHH
  • 26 Answers
Go to the bleemin Jabra website! (http://www.jabra.com/Sites/Jabra/NA-US/Headsets/Pages/JabraBT150.aspx)
"When I put the charger on for the first time after purchasing and plugged it in there was just a quick blue flash but no lights came on ever."
This one is more fun. The charger that comes with the bluetooth WILL plug in 180 degrees from proper.
Symptom of reverse plug-in is usually a dull(VERY dim) blue glow and a high pitch whine. Depending on
the parts used in your production batch, one inverted plug-in could have popped something. Try rotating the plug 180 degrees, and seeing if the charging light doesn't come on(if it does, then you're good, if not, return for refund, or you're fubared)
Posted on Jun 01, 2009
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
How to connect .
That's how you do it for other jabra's but not this one. You have turn it on then after it's on you have to hold the function (same as power button) and the volume up button at the same time until the light turns solid.
Mar 25, 2009 | Jabra BT150 Wireless Headset
Is my phone compatible w/ the jabra bt150??
bluetooth headsets are compatible with any phone that has bluetooth to connect just while its off, holding down the power button untill a constant red light comes on. then searching for the headset
Mar 18, 2009 | Jabra BT150 Wireless Headset
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Jul 28, 2008 | Jabra BT150 Wireless Headset
Lost instructions BT150 how to connect to phone?
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Goodluck
Apr 27, 2008 | Jabra BT150 Wireless Headset
Jabra BT150 compatibility
Went to Jabra could not find the number you gave for the phone. It is compatible with Nokia phones but does not show this number. Sorry.
There's a 6162 and it is compatible.
Let me know if the number you gave is correct.
Mar 02, 2008 | Jabra BT150 Wireless Headset
Jabra BT150
DO AS THAY SAID HERE.......Press power button and the - and + volume buttons at the same time AND THEN WHEN THE BLUE LIGHT STOPS ON !!!!! GO TO YR PHONE AND SEARCH FOR THE HEADSET WHEN U HAVE FOUND IT ON YR MOBILE TIPE .........0000...... then you will be sorted
hope this helps c ya
Nov 04, 2007 | Jabra BT150 Wireless Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Setting up pairing
# Fully charge your Jabra BT150 and switch on by pressing the answer/end button # Press the answer/end button and the volume up (+) button together, to put the Jabra BT150 in pairing mode # Set your mobile phone to ?discover a Bluetooth device? (see your phone user guide) # Press Yes or OK when asked if you want to pair the phone with the Jabra BT150 # Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK # Your phone will confi rm when pairing is complete
Jan 05, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
264 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
