Question about Kitchen Ranges
Anti-tip bracket for Amana ACF422GAW
Do you know about the lawsuit whereby Sears is supposed to install anti-tip brackets for many of the ranges it sold. I have an Amana Big Oven model ACF422 GAW. Now the manufacturer no longer makes the anti-tip bracket so what is Sears supposed to do about this? There must be another anti-tip bracket that will work just fine. It has taken from May until August for me to find out that the part is no longer being manufactured by Whirlpool/Amana.
I happen to be a real estate agent and I know this was a real issue in a recent sale and the sellers had to jump through hoops to find something that worked. I wasn't involved in it so I don't know how they found one, but I do not want this issue when I go to sell. I appreciate any answers you can give on this "hot" topic--get it? A cooktop, stove, hot....
Thats the stupidist thing ive ever heard.
Get a propowe bracket, which goes around teh foot of the stove.
Posted on Oct 02, 2008
Screw in a piece of wood or metal that stickes out a little ways horizontally across the back of the stove. Screw another piece of wood or metal onto the wall a tad bit higher then the one on the stove. Now the stove can't tip over and it'll be easier to manuver into place.
Posted on Aug 25, 2008
SOURCE:
I have an Amana MVH230W-01 microwave. It is probably 20 years old and I am trying to remove it. I unplugged it and removed any screws I could find, including the 3 in the upper cabinet. Now it will tip...
You can try checking out the installation manual for an idea of how it was installed. It should be sitting on a mounting bracket and not attached to the sheetrock itself. However, you might be pulling on the mounting bracket when you tip it forward. You should have an extra set of hands to help you pull it straight forward and out, instead of tipping it.
The installation manual can be found at https://d1vofmza27mmhi.cloudfront.net/product-pdf/amana-amv1150vaw-installation-instructions.pdf.
Oct 11, 2018 | Amana Microwave Ovens
Tip
Replacement of Whirlpool part 77001257 by 8203529 for Amana ARTC8600WW range...
Control switch for dual heating surface element in our Amana ARTC8600WW range (year 1999) failed and did not cycle power after the heating element was turned on. The range was in very good condition so we wanted to replace the switch. However, the original Amana part Y0315855 was not available. The company was taken over by Whirlpool and we found that Whirlpool part 77001257 should be used. But that part was not produced anymore either. On Best Buy web site we found information about an alternative 8203529 Whirlpool part. We order it, installed into the range, and got no action. From other web sites we quickly learned that the part is not the right replacement and that there is no replacement switch for our range at all. We hesitated to replace entire range so instead of returning the part to Best Buy we decided to investigate the differences between the original part and 8203529. Soon we began to believe that 8203529 should work. Specification as well as all connections were fine so we tried to adjust a little bit the tension of bimetallic element inside the switch. There is a tiny screw accessible for this purpose. The adjustment can be done be a 5/64 hex key which, for electrical safety, we insulated by a plastic tube. Immediately we got the expected action. We tested all settings before mechanical installation and all of them worked very well. The mechanical installation of the switch needed a makeshift bracket to distance the switch from the back of the panel wall in order to get the position of the switch knob properly leveled with the front wall of the panel. Just shortening the shaft of the switch was not sufficient. The bracket that comes with 8203529 was not suitable for our range. It was not difficult to make another bracket so we repaired the range without compromising its functionality or safety. That confirms that part 8203529 can be used in place of Whirlpool part 77001257.
on Sep 06, 2015 | Kitchen Ranges
I need a wiring diagram or schematic for an Amana Model AGDS902E Gas Range
http://www.appliancepartspros.com/parts-for-amana-agds902e-p1131831n-e.html
They have some diagrams, offer manuals, parts, & how to videos
24/7 Customer Support
app-logo.png?d=0914142
365-day-returns.png Amana + RangeAmana Range AGDS902E / P1131831N E Parts
Amana Range AGDS902E / P1131831N E Repair Parts Start New Search
SHARE:
Chat with a Pro AGDS902E / P1131831N E Range-S/c S/i Ddraft Gas Search
Most Popular Parts for Amana AGDS902E / P1131831N E whirlpool-oven-igniter-786324-ap2934763_01_th.jpg Sale Oven Igniter (9) View Repair Video whirlpool-top-burner-igniter-y0316773-ap4283295_01_th.jpg Top Burner Igniter View Repair Video whirlpool-broil-pan-set-4396923-ap3837379_01_th.jpg Broil Pan Set View Repair Video whirlpool-bracket-3801f656-51-ap4395315_01_th.jpg Bracket (2) whirlpool-sensor-temperature-y0314907-ap4282440_01_th.jpg Sensor, Temperature View Repair Video whirlpool-module-w-bracket-32020101-ap4041505_01_th.jpg Module W/bracket (1) View Repair Video whirlpool-oven-door-hinge-r0706010-ap4251866_01_th.jpg Oven Door Hinge, Left Side
whirlpool-assy-hinge-right-r0706011-ap4252510_01_th.jpg Assy, Hinge Right Download Manuals for Amana AGDS902E / P1131831N E Range-S/c S/i Ddraft Gas - Owner's Manual How to Troubleshoot and Repair Amana AGDS902E / P1131831N E Real advice from real customers just like you
Do-It-Yourself Stories from Customers like You Stephen F. bought this part whirlpool-oven-igniter-786324-ap2934763_01_th.jpg sale
Whirlpool Oven Igniter View Repair Video Oven took long time to ignite and when it did it came on with noise Stephen F. • Star Junction, PA • June 20, 2014 My Repair & Advice I looked up oven igniter on line and watched video, very helpful, then called and a women was able Read More...
Was this review helpful to you? 2 People found this story helpful
Do-It-Yourself Rating
  • 1
  • 2
  • 3
  • 4
  • 5
Easy Difficult Repair Time Estimate
Less than 15 minutes Corey B. bought this part whirlpool-bracket-3801f656-51-ap4395315_01_th.jpg
Whirlpool Bracket Needed anti tip plate Corey B. • Portland, OR • November 03, 2014 My Repair & Advice By moving the stove, installing with a few screws and sliding it back into place.
Was this review helpful to you? Do-It-Yourself Rating
  • 1
  • 2
  • 3
  • 4
  • 5
30-60 minutes How-to Videos for Amana AGDS902E / P1131831N E How to Replace Oven Igniter
How to Replace Top Burner Igniter
How to Replace Broil Pan Set
How to Replace Sensor, Temperature
Nov 25, 2014 | Amana Kitchen Ranges
How to install anti rattle spring 97 softial break pads
Hi Anonymous, the rear caliper must be off of the mounting bracket, the anti rattle spring holds the top of the inboard pad and clips into recesses next to the caliper pin bushings on the back side of the caliper mounting bracket. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 10, 2014 | 2000 Harley Davidson FLSTC Heritage...
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
Dec 17, 2017 | Samsung Microwave Ovens
Where and how to install anti tip bracket
The anti tip bracket is installed along the baseboard area BEHIND the range, so that one of the rear feet on the appliance will slide into it when pushed against the wall. Once installed, the rear foot of the range is slid into the bracket, holding the rear foot to the floor. This effectively prevents the range from tipping forward.
Installation instructions are included on page 3 of the Installation Manual that came with the appliance. If you no longer have a copy, you can obtain a replacement at managemylife.com. Just enter your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format. You can download or print a copy for FREE. For your convenience, here's a direct link:
http://www.managemylife.com/mmh/installation_guides/3001/MAYTAG-Free-Standing-Electric-L0502644?brand_name_search=mer5775q
Figure 3 shows an excellent illustration of how the bracket is to be installed.
If you have any questions, please post back and let me know. I hope this helps you.
Oct 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Oven anti-tip bracket
Hi Jodie,
The anti-tip kits are installed on the floor behind the oven. They're installed BEFORE the oven is moved into place. They are "U"-shaped and when the oven is slid into place, the "U" locks into the back legs of the oven to lock it down.
You can tell if yours is so equipped by simply sliding the oven out away from the wall about 10 inches then looking behind it on the floor. Slide the oven out by opening the door about 5" and place your hands inside... then lift and pull toward you at the same time.
Here is the anti-tip kit for yours... If you see this down there, then you're good to go. If not, order both of those parts (in the previous link) 'cause you'll need them.
Hope this helps!
SG
Apr 22, 2009 | Ovens
Side mount brackets for kenmore dishwasher
Where can I can sears part # 170664 side mount bracket for a kenmore dishwasher mohel 13593?
Nov 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kitchen Ranges Logo
470 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
