SOURCE: S500 Mercedes Leather Arm Rest Worn
You may try an upholstery shop, one that deals in auto restoration, convertible tops , etc. Auto parts stores are a good resource for info. Those guys behind the counter know a lot, and may be able to lead you in the right direction. You may be able to save a few hundred bucks, maybe more.
SOURCE: i have the panel loose but cannot not take apart
usually there is some sort of plug youll have to pop out with a flat head screwdriver then more than likely a large phillips screwdriver to take out the screws which are in deep,hope this helps but cant really picture an armrest in back of mazda
SOURCE: I have a 2006 BMW 750li, removal of gas pedal
IF YOU ARE GETTING A THROTTLE PEDAL POSITION SENSOR FAULT CODE.THE THROTTLE POSITION SENSOR IS THE WHOLE THROTTLE BODY UNIT IS THE THROTTLE POSITION SENSOR.THE SENSOR NOT IN GAS PEDAL LIKE VOLKSWAGON. VOLKSWAGON HAS THE ACCELERATOR PEDAL POSITION SENSOR.
SOURCE: the internal screw/washer with plastic
hi
here is cosco contact details
http://www.coscojuvenile.com/usa/eng/Contact-Us
